RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Official E-FIRESTORM thread
Reply
Old 06-19-2008, 05:21 PM
  #326
ElectricGuy007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official E-FIRESTORM thread
ORIGINAL: supamagician
ORIGINAL: B44&501xRacerEX
I found the error. HPI messed up these kits and got the springs mixed up.
If you switch the front springs with the rear springs the the truck is dialed for the track.
I noticed the springs are different from each other.
So there's no sense on wasting money on springs when the stock ones are just fine, just switch 'em around.
Switch just the springs, or the whole shocks?
Also, what tires are you racing with?
What is probably the fastest brushed motor (That is also good for at the track) to put in the Storm?
Just the springs.
I would go with a team checkpoint series brushed. At least that brush technology is for longer life, and more power.
A guy at the track runs a 12 turn team checkpoint motor in his T4.
I went the brushless route right away though.
The post above says I used the stock tires at the track it works on hard packed clay and Loose dirt as well.
ElectricGuy007 is offline
Old 06-19-2008, 05:39 PM
  #327
supamagician
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh ok. well will you check out this video? http://www.metacafe.com/watch/124082..._at_the_track/
what do you think im doing wrong? what do I need to improve on? do I need new tires?
the reason I am asking these questions is because I was sliding around alot, and I want to be a good racer, but its hard when your sliding everywhere
supamagician is offline
Old 06-19-2008, 08:12 PM
  #328
grimreeper621
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does anybody know if the wheels from the losi dt will fit the e firestorm, because i really like the losi dt rims and i dont feel like going out to buy them and then they end up not fitting
grimreeper621 is offline
Old 06-20-2008, 03:08 AM
  #329
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: :-)
Could anybody post the dimensions of the e-firestorm's battery tray?
cheers
If you are worried about number of cells, it'll take 7 C Sub C in stick or side by side configuration.
No hump packs with default battery retainer.
dafpnp is offline
Old 06-20-2008, 06:19 AM
  #330
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Consider 1) increasing wheel base of your setup, 2) have a stiffer differential.
Practice smoother inputs, atleast when you are negotiating turns.
dafpnp is offline
Old 06-20-2008, 10:54 AM
  #331
brianmhaskell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Who has the most efficient gear setup for a stock efirestorm. I did the calculator and it looks like I should keep the spur gear at 87teeth and change the pinion from 19t to 31 teeth. Would this work well?
brianmhaskell is offline
Old 06-20-2008, 11:28 AM
  #332
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, 31 T pinion ... will it fit. I doubt.
How did you arrive at a figure of 31.
Per calculations, 19T is the optimum setup.
Go up or down couple of teeth for speed or torque.
Keep watching your motor and esc temps if you go above 19T.
dafpnp is offline
Old 06-20-2008, 01:07 PM
  #333
ElectricGuy007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm running a 9.5 lrp brushless motor with the stock pinon. No heat issues so far.
I had a guy look at this truck is it 48 pitch or metric? So I can use 87 tooth T4 spur gears as a replacement?
I'm pretty darn sure it's 48 pitch, just not 100% sure.
Old 06-20-2008, 01:17 PM
  #334
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its 48.
dafpnp is offline
Old 06-20-2008, 11:52 PM
  #335
ElectricGuy007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I must say the 9.5 brushless motor I chose was a good choice at my local track.
And the stock tires really hooked up fine there also, but might not work everywhere.
This chassis has alot of race potential for what it is.
thread shocks, high quality parts, everything in between.
Although some parts need to be replaced to have a stronger race truck.
The stock ball-studs are not ment for racing and will break very easy, so it's best to replace them with AE or losi ball-studs.
And cap the the ball-stud ends off with lock nuts, then use a drop of blue threadlocker.
And since the ball-studs are upgraded get you some matching black RPM ball-cups also.
Drain the old oil out of the shocks and re-fill them with 25,30,35-40wt shock oil depending on the track conditions.
Old 06-21-2008, 05:48 AM
  #336
sbracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here is a video of mine i dont race i just mess around with it. it has a mamba max with the 5700 motor on it. i have run up to 11 cells but i just got a couple lipos to try out.
http://youtube.com/watch?v=0NpMQVjYqDg
sbracing is offline
Old 06-23-2008, 01:25 PM
  #337
Enzyme80
Enzyme80's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice vid although you might want to turn down the audio track a little ouch! Should have the sw 4600 soon and cant wait. What battery were you running for that? Currently I have nothing good for batteries but will be upgrading them somewhat soon but still staying with nimh. I hate waiting for things but my LHS did not have the SW or MM so I had to order online ughhh waiting sucks.
Enzyme80 is offline
Old 06-23-2008, 11:44 PM
  #338
ElectricGuy007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hum this E-firestorm looks very familiar? Are you Vroom from rcworld?
Looks like this is a race ready one for the track. Cool!
Belive me I got hit with the brushless bug and I was hooked for sure.
I have not even tried the stock motor and esc and radio yet(still in the plastic), I have decided to put them in my blackfoot extreme basher instead.
Old 06-24-2008, 11:59 AM
  #339
sbracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does anyone know if there is a steel spur gear made fore this truck or an associated truck???? i keep stripping mine.... i have it setup to drag race but it keeps stripping the gear on the launch
sbracing is offline
Old 06-24-2008, 12:07 PM
  #340
ElectricGuy007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I swapped mine over to a Kimborugh 87 tooth T4 spur gear, and B4/T4 slipper pads.
Yeah my spur was starting to strip also so I had to swap it out.
Might have something to do with the stock motor screws because they are way too short.
I ended up replacing those also with some longer ones.
Old 06-24-2008, 12:24 PM
  #341
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you use paper technique to adjust the gap between pinion and spur.
It really works well.
dafpnp is offline
Old 06-24-2008, 12:54 PM
  #342
sbracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yup... i do use that technique(not saying im doing it right though) lol
sbracing is offline
Old 06-24-2008, 12:58 PM
  #343
sbracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kimborugh 87 tooth T4 spur gear is the one i stripped yesterday... i gotto look to make sure nothing is bent
sbracing is offline
Old 06-24-2008, 02:48 PM
  #344
brianmhaskell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey e-firestorm fans. I am interested in upgrading my motor from the stock 15turn. I don't want to change out the esc, so what is the best 15turn that i could buy in a case like this?
Old 06-24-2008, 03:57 PM
  #345
Frozen72
Frozen72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had good luck my Method Sv2 by Orion. I really want to get one of these to replace my Rustler... How is the servo and ESC?
Frozen72 is offline
Old 06-24-2008, 07:38 PM
  #346
Enzyme80
Enzyme80's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The servo is a little slow but I guess that is normal for stock. I haven't had problems with it yet but am finding that I want stronger and faster response. I know nothing about the ESC besides it can do 15 turn motors
Enzyme80 is offline
Old 06-24-2008, 07:46 PM
  #347
Frozen72
Frozen72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks I was just making sure that the ESC was reliable and not a ticking time bomb. I would end up getting a Digital MG servo anyway.
Frozen72 is offline
Old 06-25-2008, 02:35 AM
  #348
AlphaDOG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I want to buy BALL STUDS and BALL CUPS upgrades for my new e-fs which one do I need from this site ?
http://www.lunsfordracing.com/mm5/me...gory_Code=BALL
AlphaDOG is offline
Old 06-25-2008, 08:13 AM
  #349
brianmhaskell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks look like a good choice. Anyone else?
Old 06-25-2008, 04:26 PM
  #350
Frozen72
Frozen72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lunsford makes great stuff I would get them.
Frozen72 is offline
Contact Us Archive Advertising Cookie Policy
