Official E-FIRESTORM thread
#3651
RE: Official E-FIRESTORM thread
question... id like to avoid loosing body clips. while i like the dubro retainers im not about to drill another hole into the body. so whats being used in the very first pic of this thread. id ask "allicedout" but he hasnt signed in in a year. thanks
#3652
FL
Well got my Firestorm in on Friday. I plan on upgrading to brushless in the future after the brushed motor craps out on me. Here is some pics and a vid of it. http://www.youtube.com/watch?v=-b4uRAj2yyU
#3653
1 Post
ORIGINAL: jsmrc
question... id like to avoid loosing body clips. while i like the dubro retainers im not about to drill another hole into the body. so whats being used in the very first pic of this thread. id ask ''allicedout'' but he hasnt signed in in a year. thanks
#3654
1 Post
ORIGINAL: rclugnut10
whats peoples thoughts on HPI's CVD kit???
the lug
the lug
#3655
1 Post
ORIGINAL: jg2009
#3656
VT
ORIGINAL: redfisher1974
I have heard they are not worth the coin, And they break the pin alot.But this is only hear say
the lug
the lug
i can't wait to get mine!!! the guys shipping tommrow yay,
the lug
#3657
i have a question about this car . if you goo full speed reverse then full throttle forward nothing will happen to the diff right?
someone told me about this abit too late but nothing seems to be wrong.
oh and let me say this car is awesome on the dirt!
#3660
im running 2 turnigy 5000 mah 2s 20c li-po to run more voltage instead of more mah and these two cool looking things [link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6667&Product_Name=KD36-50-06S_5900kv_Brushless_Inrunner]motor[/link], [link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8993&Product_Name=Hobby_King__Brushless_Car_ESC_100A_w/_Reverse_(Upgrade_version)]ESC[/link]
#3661
VT
that motor has a 5mm shaft 48P pinions with that shaft size are gunna be hard to find unless you don't mind drilling them out yourslef and if you do, do it in small steps so you're only taking off maybe .5mm at a time, yes this will take a while and cost a little $ in bits but you'll get it centered way better than if you try go from 3mm to 5mm in one shot....
the lug
the lug
#3662
1 Post
ORIGINAL: vpower
lets say you run the stock gears 19/87 and lets say bow-tie tires you would be pushing 77 mph's [X(] that would be cool to see.
Differential Ratio: 1
Transmission Ratio: 2.6
Other Ratio: 1
Spur Tooth Count: 87
Pinion Tooth Count: 19
Total Voltage: 14.8
Motor KV: 5900
Tire Diameter (inches): 3.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 4.58 : 1
Total Ratio: 11.90526 : 1
Tire Circumference (inches): 11 inches (279.29 mm)
Rollout: 0.92:1
Total Motor Speed: 87320 RPM
Vehicle Speed: 76.37 mph (122.68 km/h)
Effective KV Value: 5900
KT constant: 0.23 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
#3664
the lug
the lug
not trying to be mean just that i have no idea what your talking about if your talking to me[]
#3665
VT
ohh yeah sorry i was, i forgot to quote it and then didn't bother cuz i was half way thru it, no hard feelings happends all the time, the internet is no where's near the most effieceint or accurate means of communication.......
the lug
the lug
#3666
there is one thing i didnt like about this stadium truck. the steering radius stinks it barely turns at alllllll!
is there a way to fix that?
#3667
thats alot of rpm's 5900 x 14.8 = 87,320 what gears and tires are you running?
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 5900
Rollout: 0.92:1
ORIGINAL: vpower
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 5900
Rollout: 0.92:1
#3669
ON, CANADA
vpower, have you run that setup for very long? I couldn't get a novak 4200kv ballistic motor to hold up to that voltage beyond two charges.
#3670
1 Post
ORIGINAL: vpower
how long did it take you to do that math???
#3671
1 Post
ORIGINAL: nitro-rob
#3672
ORIGINAL: nitro-rob
and did you read the specs of that novak you cant put more than 2s li-po because of its design i mean i would have tried 3s but with care.... so basicly you screwed up there my friend.
#3673
about 45 seconds follow link-> http://www.scriptasylum.com/rc_speed/index.html
ORIGINAL: vpower
Hi Red
My up and coming speed attempt will be using the following, not sure how you figure out the ratios for your speed calculator
VXL Motor - 3500kv
Battery - 3s 11.1v
Pinion - 30t
Spur - 77t
#3674
feeling stupid!!!
I just looked at Red's example and not the attachment, did'nt realise scroll downs would have Firestorm details.
Anyway my attempt should be good for 68mph, blitz 77t spur and Edit 30t pinion are in the post.
#3675
70 mph is enough for me but sooner or later i will modify the chassis for less weight, put a fan on the motor and run a bigger pinion and smaller spur. and maybe put big bore shocks for the fun of it. im already thinking of some good foam tires and maybe with all this i will achieve at least 85 plus mph (btw what is the fastest speed record on a rc race track?)
