RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Official E-FIRESTORM thread
Reply
Old 06-25-2008, 04:33 PM
  #351
Vrooom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official E-FIRESTORM thread
Hey, as e-firestorm user, i got fed up breaking the weak spot and loosing dog bones on my brushless e-firestorm, so i decided to create this, beefy rear end using rod ends and a plate to hold it togother I hope it worked.
My firestorm is all standard apart from mamba max esc / 5700 motor with 11.1v lipo. shes fly! the ball stud broke twice, after gentle bashing (clearing a bmx jump set), and barrel roll. so here is the pic, ingore my crude handiwork on those parts! lol.
Vrooom is offline
Old 06-25-2008, 04:45 PM
  #352
supamagician
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dafpnp
ORIGINAL: supamagician
oh ok. well will you check out this video? http://www.metacafe.com/watch/124082..._at_the_track/
what do you think im doing wrong? what do I need to improve on? do I need new tires?
the reason I am asking these questions is because I was sliding around alot, and I want to be a good racer, but its hard when your sliding everywhere
Consider 1) increasing wheel base of your setup, 2) have a stiffer differential.
Practice smoother inputs, atleast when you are negotiating turns.
Ok. Thanks for the advice. Besides changing shock positions, how could I increase the wheelbase? Also, what is a differential, and how can I make mine stiffer?
supamagician is offline
Old 06-25-2008, 05:41 PM
  #353
mercerbeef
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i was woundering if you all know that nitro firestorm parts fit on the estorm? (arms,hubs,knuckles)
i got alum. steering knuckles, alum c hubs, alum.rear hubs, alum. arm mount and brace (from hotracing) via hobbyect.com
its got a 5700sidewinder, proline steppins, various hpi rims, and a spektrum 3.0 (which didnt work with the stock esc setup)
hpi alum shocks front and rear ( theyr on my nitro storm for the summer)
lunsford turnbuckles
just got my castle link so i'll try some different setups before next season ( we race indoors in winter)
mercerbeef is offline
Old 06-25-2008, 07:01 PM
  #354
mercerbeef
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heres some pics, forgot to mention i got losi springs on alum shocks, had to use losi spring perchs, and the new body i had on got trashed when i put it on my nitro firestorm
ID:	978510   Click image for larger version
ID:	978511   Click image for larger version
ID:	978512   Click image for larger version
ID:	978513   Click image for larger version
Old 06-25-2008, 07:13 PM
  #355
powerslider
powerslider's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOW, there's the beef!! I bet you don't have problems there anymore lol.... Nice job..
powerslider is offline
Old 06-25-2008, 08:46 PM
  #356
ElectricGuy007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Enzyme80
The servo is a little slow but I guess that is normal for stock. I haven't had problems with it yet but am finding that I want stronger and faster response.
But remember if you upgrade the servo to a "digital metal geared servo" you'll get less runtime.
I wouldnt worry about it if your running Lipo batt's though.
I still run nimh and for my second practice day at my local track it was successful with the stock servo.
I cleared all the jumps and turns just fine with it.
Yet the track record is 19.1. This past weekend I got a 19.5 on one of my laps.
I hoping for a great race this weekend with this truck.
ElectricGuy007 is offline
Old 06-26-2008, 12:46 AM
  #357
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dafpnp
Look for my post on this forum at page 9 for wheel base settings.
Differential....I'll post later.. in a hurry now.
dafpnp is offline
Old 06-26-2008, 01:07 AM
  #358
supamagician
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys, I need some suggestions on how to fix this. You know the little wall that separates the battery from the servo. Well that little wall broke off, and now, if I run to hard, the battery pushes the servo forward, and causes steering problems. I dont know where the little wall is, I just know its not there lol.
Old 06-26-2008, 01:14 AM
  #359
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For me, it cracked... but didn't break completely.
Your options: :-) create a new wall.
Find out / create a similar sized piece. Rough up side walls with a 1.5mm drill or some thing and then use 30 minute epoxy [I used m-seal] to fix the wall.
The roughened sidewall will give more strength to the epoxy to hold on to the side walls.
It seems you have also broken the servo body, which holds on to servo posts. It happenned in my case + also a bent stick pack :-(. I am happy I wasn't running a lipo at the time of crash.
dafpnp is offline
Old 06-26-2008, 11:56 AM
  #360
brianmhaskell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's a sweet storm!
brianmhaskell is offline
Old 06-26-2008, 02:37 PM
  #361
mercerbeef
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks i used tamiya clear orange paint on the aluminum
about the ball studs breaking, i remembered earlier today that my old xxxt busted em a few times when i first started, and it turned out to be no shock oil in the in the shock and dead springs, and i recall someone mentioned hpi put the wrong springs in the front and rear. could that be the problem?
Old 06-26-2008, 08:05 PM
  #362
brianmhaskell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I have a stock E-Firestorm and replaced the pinion with a 20tooth. It is so much faster and nothing runs hot. I would recommend this setup for all out there that have the stock setup. It set me back a whopping $3.50
It also runs perfectly cool so no issues with electronics
Old 06-27-2008, 11:18 AM
  #363
supamagician
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: dafpnp
actually, what I think I'm going to do is put some velcro down where the battery sits, and put velcrow on the bottom of all my batteries. That way the velcro will hold the batteries still, and I can easily adjust the battery position to change performance (forward for better steering, back for more wheelies etc.).
Old 06-27-2008, 11:20 AM
  #364
ElectricGuy007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been using the foam battery things it came with have you?
It says in the manual that you can position the foam blocks to do wheelies, or balance it out for racing.
I didnt even know stadium trucks could do this.
Old 06-27-2008, 11:50 AM
  #365
supamagician
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah ive been using them. just would be easier with velcro I think
Old 06-29-2008, 03:51 AM
  #366
AlphaDOG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have just received my e-firestorm I plan to put brushless in it if someone want the stock motor & esc let me know never used brand new .. 60$ + shipping.
AlphaDOG is offline
Old 06-29-2008, 01:56 PM
  #367
bgagnon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all,
I am new to this and I have a stock e-firestorm. I would like to know where you buy your parts on the net. Where they have good supply, Good service and fast shipping. I live in canada and I want to upgrade. Where can I find a cheap brushless kit to replace my stock motor and ESC.
Also brianmhaskell, where did you get your 20 tooth pinion.
Thank you,
Nick
bgagnon is offline
Old 06-29-2008, 02:45 PM
  #368
dafpnp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am from India and I usually get parts from towerhobbies.com or omnimodels.com
They are basically the same.
Tower offers more discounts
Omni offers cheaper shipping.
dafpnp is offline
Old 06-29-2008, 03:33 PM
  #369
brianmhaskell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bgagnon
Hi all,
Thank you,
Nick
Hobbypeople.net is always cheaper than tower hobbies when you look at the overall picture (shipping).
I use robinson racing pinions remember to use 48 pitch. I am know using the 21tooth and it is pretty fast.
Old 06-29-2008, 05:35 PM
  #370
bgagnon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the quick reply. That will help.
You guys rocks,
../Nick
bgagnon is offline
Old 06-30-2008, 04:12 PM
  #371
sbracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
took the firestorm on road to mess around with it. here is a pic of it just before i ripped of the wheelie bar
sbracing is offline
Old 06-30-2008, 06:20 PM
  #372
sbracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://youtube.com/watch?v=MXyEAR_sGD4
http://www.youtube.com/watch?v=P-mrANEzhlc
video of it
sbracing is offline
Old 06-30-2008, 06:44 PM
  #373
SAVAGEBANE
SAVAGEBANE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i am interested in a new ST. the only one i have now was my first r/c a rustler...a really old rustler. i have done some good upgrades, but its time to shelf it for decoration cause i dont wanna keep pouring money into it.
i was gonna get a new vxl rusty, but i just considered the e-firestorm. i do eventually wanna get into racing. is th FS honestly better than vxl for racing and why if possible.
SAVAGEBANE is offline
Old 07-01-2008, 07:21 AM
  #374
sbracing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
do any of you have any advice on how to keep my front end down. it has a wheelie bar and it has the battery tray that came with my futaba stuff just sitting in there as ballast and i use the 10 cell for the extra weight(battery was built with the top cells in the front). i can forget about using the lipo. i was at work last night messing with it. i went the whole lenth of the homedepot i work at before i hit the throttle 100% and it still flipped over lol
sbracing is offline
Old 07-01-2008, 07:58 AM
  #375
brushlessboy16
brushlessboy16's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you got more pics of your bar?
brushlessboy16 is offline
Contact Us Archive Advertising Cookie Policy
