Official E-FIRESTORM thread
#551
NJ
RE: Official E-FIRESTORM thread
ORIGINAL: AquarianGuy78
One more thing...I talked with a fellow E-Fs owner and he said to make sure you use loctite on the differential bolts to make sure it doesnt come loose.
ORIGINAL: 73
-The brushed E-Firestorm does come with a servo saver, it's at the bellcrank (is that what it's called?) area.
-For those who've filled the diff with silicon oil, does it leak? I filled mine with 1000wt silicon oil and it leaks out from the outdrives after 2 packs. After replacing the oil seal inside the diff case, the same thing happen. I'm probably going to stop running diff oil if it is not working out.
-Has anyone got his hands on the replacement front arm of this truck??? I've a pair back-ordered for months and yet to see them, so I'm wondering if HPI ever released replacement front arms. As for the rear arms, they have been available for a long time now.
(I'm new, correct me if I made any mistakes. )
#552
NJ
Has anyone had issues with the stock E-Firestorm trans. with a brushless motor installed? Also does the RTR ($200) version come with all metal internal gears?
#553
ORIGINAL: heta peta
#554
NJ
OK, I just ordered an E-Firestorm from EHOBBIES.COM, it was a good deal at $191.00 plus shipping. I also bought a new condo. today, so the wife is gonna love this one[:@]
#555
NJ
I am gonna put the MM 5700 in it. I use it with the pede and used to with the evader. it's just cheaper to swap the same motor and ESC between trucks.
#556
ORIGINAL: 73
All gone after only 2 runs! I've been using Associated 30K diff fluid so far. It does leak out some at the outdrives but my experience with 30K is that it will last quite a while. Maybe just packing it full (or at least more than what came in it from the factory) of some heavyweight diff grease will let you go much longer between servicing and still provide some limited slip. The truck just drives a whole lot better when the diff is tight like that and getting plenty of power down to both wheels. From the factory it pretty much behaves like an open diff.
I've had the front arms pretty much since the E-Firestorm came out since it is the same part number as the front arms for the Nitro Firestorm as mentioned earlier. Front arms are in stock at Tower right now.
#557
A big thank you for all the replies and advices, especially regarding the arms.
Ive searched for "E Firestorm" parts at Towers and that turned up almost empty... LOL, I should have thought of searching for HPI arms!
Thanks a ton, again.
Anyone looking at getting a electric truck, this E-Firestorm will not disappoint! I've hammered it at least 6runs/week (some times, more) for almost half a year now, and it's still going.
Only wasted the stock motor (wear & tear),
Burnt the ESC w a too-high turn motor,
Replaced rear tires (wear),
Replaced drive shafts and axles(wear).
[8D][8D][8D]
[8D][8D][8D]
#559
SK, CANADA
rear ball ends popped off my turnbuckles does anyone know a good upgrade on this can will direct fit on stock ball studs ? I know RPM but not sure about the correct parts numbers...
#560
ORIGINAL: SN33KY
Hey where do you get the axels?
lol cant find any replacements on ebay
I've got shock springs, shock tower, front "bumper and stuffs from local shops here. The one thing that bugged me was, where the h*ll are the front arms!!!
#561
Hi
I Want to make my HPI E-Firestorm as strong as possible, help me??
my upgrades so far :
Mamba SIDEWINDER 4600kv
TrakPower 7.4v 4900mAh 25C LiPo Race Pack
T-Bone Racing Front Bumper
Hitec 645MG Servo
87251 - ALUMINUM THREADED SHOCK SET (67-87mm / 2pcs)
87252 - ALUMINUM THREADED SHOCK SET (70-103mm / 2pcs)
any upgrades i need to make it stronger (bulletproof) ?
Hitec 645MG Servo
#562
what differences are ther between the e- firestorm flux and the rustler vxl. ive been looking at getting the vxl rustler and then noticed the flux. i have a stampede vxl and its pretty awesome, just wondering what you guys thought of the flux.
#563
ORIGINAL: MTpockets
#564
ORIGINAL: Always Dreamin
the rustler and stampede use a lot of the same parts, so that's a benefit. the flux is the better car, though.
ORIGINAL: MTpockets
#565
ORIGINAL: AlphaDOG
#566
QC, CANADA
i used 10,000wt diff oil, and it bled out after 2 5min races, but when i opened it there was still some in it. i asked at hpi and they said the diff wasn't made to hold oil. if you check it leaks outa the outdrives, a friend told me to use the orange seals, but theyr too small, a slightly larger one might work but the lhs hasn't got any in yet
rpms ball cups are to small, i'm doing what vrooom said lol
jakobw- go back to about page 15 for some aluminum upgrades
also the nitro firestorms arms will fit on the e-firestorm, as well as the shock towers
#567
http://www.platinumrcproducts.com/prc%20178.html
PRC178 - HPI E-Firestorm Carbon Fiber Kit
I got that.. the quality isnt really that good but i guess it is ok
And also which ballcups and turnbuckles should i get if the rpm ones dont fit?
I heard about lunsford punisher but i havent seen them on ebay yet...
#569
ORIGINAL: mercerbeef
#570
ORIGINAL: 73
When I next open up the gearox for servicing, I'm going to remove the diff oil and add some washers to "tighten" up the little "diff-adjustment spring" inside. Will then try if that work, theorectically it should...
#571
Oh ok,
I dont really have many LHS's that sell that stuff around here...
Oh yeah my diffs are filled with associated black grease...
works alright
works alright
#572
NJ
I don't see what the issue is with the diff not holding oil. It is sealed and should be holding. It even states in the description on hpi's site that the diffs can be tuned using different silicone oils.
ORIGINAL: 73
#573
SK, CANADA
I use 10,000 diff silicone fluid in my e-fs diff and it leak where the rear output shaft ... does this is the best way to stop leak ?
#574
FL
Hey guys having some issues. 30+ runs finally bent a turnbuckle. Should I get the 2 3/4" set from Lunsford or get the Associated Factory Team set same size for the T4? Factory Team's are cheaper and made of the same stuff, just blue.
