Official E-FIRESTORM thread
#1101
RE: Official E-FIRESTORM thread
ORIGINAL: bigmd74
yeah,same thing buddy.
#1102
QC, CANADA
bigmd- when i race i use the various hpi rims with steppins (or bowties depending on the track) in the rear and the stock tires and rims upfront, the traxxs rims are for summer bashing. and yes you need to use the trxs hexs with trxs rims, unless you dont mind tweeking a set of alum. hpi hexs from a e-10
#1103
yeah thanks bud.i figured it out.i was gong to dremel a set of the hpis but i ordered a set of traxxas that are slightly wider then the stock traxxas hubs.which shoul work out fine since the traxxas dish rims have a narrower offset then the hpi's.
#1104
QC, CANADA
i was told some of the wider offsets will effect the way the rear handles but i never noticed before.if i get a chance i'll try some, i got a few hpi rims with race tires on em, that i used to race on my xxxt.
#1106
FL
How does Associated silicone diff grease work in the 'Storm? Got some stuff today like the graphite front arms, seems kinda heavy for graphite though.
#1107
IA
I used associated's black diff grease in my Firestorm, it loves it. Using it actually fixed my grinding problem i was having a week or so ago.
#1108
My Feedback: (8)
WA
Hi just joined the site. I have been contemplating between a few vehicles to buy. I cant decide between the Firestorm flux, AE B44, Losi XXX4, or XXXT. It would be just for light bashing around (backyard and track) and possibly moving up to club racing later. Just wondering what some of you might think. I have nitro vehicles but as for electric I would be starting from the ground up so cost is an issue with me since I would need to buy a charger and batteries to get going. And for that reason I have been leaning towards the RTR Flux since I wouldnt need to buy a motor, esc, and radio system.
#1109
IA
Cost effective + raceable + durable for bashing = E-Firestorm Flux. All the others you mentioned are more along the lines of pure racers than the Firestorm.
#1112
MA
ORIGINAL: backyard.basher
So is this thread also for the Flux version??? I just got one and cant wait to give it a go....
Yes this is for both versions of the the E-Firestorm.
I really need to get out an drive mine some more. We are close to winter up here and generally can see a lot of snow. I am not sure if I should run the car in the snow but I figure that going without it for the winter is probably a smart idea.
Any one have a thought on how to keep the front end down at top speed? (est around 35-40 mph with the 7 cell battery).
#1113
TN
Hello guys im about to order a e firestorm not the
flux version got my own brushless setup to throw in
Well i was just wondering will this make me a
good racer or just a basher? I wanna buy it
strip it rebuild it from the ground up like
i did my evader st which is a strong ready to
race truck. Anyway i wanna know does the
truck have race potential open to everyone thank you.
#1114
IA
If you're drag racing, stick some weight up front. If not, then tame your settings, I use my 4600 at the track all the time, almost all of the settings are taken back quite a bit, it's all about control, that's what wins dirt track races.
But if you are going for top speed, I had a Traxxas Bandit that I had to anchor fishing weights to the front to keep the nose down so I could keep control of it for speed runs. It worked a little bit, maybe softer springs in front, harder in back...
#1115
IA
ORIGINAL: built2last2
#1116
TN
I will be racing on a track i tired of
running up and down the street even
though that improved my driving skills onroad
and it showed me how to set the truck up
for on road handling but now its time to
get dirty. As for servos i am a futaba freak
will a s3305 servo be good for racing or
do i need more strenght or speed? Also
for springs and shock oils i use soft springs
all around aond 40 to 45 wt in oil thats onroad
of coarse will i need to change springs also?
#1117
NY
ORIGINAL: Enzyme80
#1118
MA
ORIGINAL: meanstreak1
I'm running FlUX/LIPO and the front end is pretty stable except for quick take offs when sometimes it flips. Do you have the battery all the way forward?
ORIGINAL: Enzyme80
It is a 7 cell batter so there is no way to make it any more forward than it is. I might try to lower the setting a little and see if that helps. I dont know my body is a little beat up now from the crashs and what not so it probably does not have as much down force as it used to. I was going full speed and the car flipped onto its body. It was wicked funny to watch but put some nice scapes in the body as well. I am going to try the fishing weights to see if that helps.
I might also try to rig something up for more down force as long as it does not take away from off roading.
#1119
Hi, I've just bought this wheels:
[link]http://www.hpieurope.com/piw.php?lang=en&partNo=4451[/link]
Does anybody know which foam inserts I can use?
#1120
IA
If they're not that much smaller than a normal stadium truck tire, I guess you can pick up whatever foams you want and trim to fit. I've never bought tires that didn't come with foams though, even all the HPI tires I've bought came with foams.
#1121
has anyone adapted any other bodies to the firestorm,proline,hpi ,etc....i like this http://www.hpiracing.com/products/en/7161/
but i know the nitro firestorm has diffewrent shock towers.i was thinking of cutting holes in the body to let the towers come through,but im thinking that may be a little hack.
#1122
QC, CANADA
for you guys doing top speed runs, have you tried using the rear wing off a street car? just mount the wing to the front of your truck and it should give you enough down force to keep the front down. i remember seeing an '80's era lamborghini countash with a wing on its nose
bigmd- i had the mx-1 on mine but the rear shock towers are too tall, if you readjust them the body sits a little high, my body was old so i just cut holes in the bed area to clear the shock mounts. if you look in my gallery you'll see the mx-1 on a tl-01
