RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Tamiya Pajero-Collective Build
Reply
Old 01-22-2009, 12:55 PM
  #801
Bok
Bok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tamiya Pajero-Collective Build
Quote:
ORIGINAL: sasse2323
Here it is. Bought kit from lunchboxer. One pic shows how i lifted the body. I used plastic tree parts from the kit. Hpi Wheels and highlift tires. ball bearing set. I am only getting 5 min runtime on a fresh 3300nimh battery. My rc10 with a mamba max 7700 gets 15 min on the same battery. Should i put the mamba in the pajero? What are my other options? Is the drivetrain that inefficient? or is the voltage cutoff on the tamiya esc too high?
Nice Pajero! [8D] I get more runtime than that with my 10 year old 1400 nicd pack. Yours might be over-geared, check if you have the 16T pinion in there and not the 20T. Otherwise it looks like your battery is on its last legs
Bok is offline
Old 01-22-2009, 08:16 PM
  #802
jncwhite
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have the traxxas xl5 in my pajero. what is the highest turn motor i can run on it
jncwhite is offline
Old 01-22-2009, 09:09 PM
  #803
NjBasher
NjBasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jncwhite
15 turns
NjBasher is offline
Old 01-22-2009, 09:18 PM
  #804
NjBasher
NjBasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i wanna lift the rear the rear of the body but afraid to cut up the rear body mounts
NjBasher is offline
Old 01-22-2009, 09:20 PM
  #805
sasse2323
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well i figured it out. Its the crappy tamiya motor and ESC. I took the mambamax 7700 out of another car and put it in the pajero. It is AWESOME. I used the stock 16 tooth pinion. Might have to go down a couple teeth, it has a tiny bit of lag. To make it fit you have to cut away some of the plastic motor cover. The mamba's can is the same diameter, but there are three screws hanging out the side of it. Awesome.
sasse2323 is offline
Old 01-22-2009, 09:22 PM
  #806
sasse2323
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Krawler, look at my pic of the body mounts i posted on the last page. Easy to do. Cut off nub, leaving the disk for the body to rest on. Drill holes right above the disks. Stick in wasted plastic tree parts from the kit and epoxy in. Takes 5 mins.
Old 01-22-2009, 09:36 PM
  #807
NjBasher
NjBasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wish i had some epoxy best i got is ca clue
NjBasher is offline
Old 01-22-2009, 10:05 PM
  #808
sasse2323
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ca Wont work for that. You can get epoxy almost anywhere now. walgreens,gas stations,hardware stores. Good luck.
Old 01-22-2009, 10:37 PM
  #809
manerdie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so using the stock tamiya esc is not advisable to use? whats the difference when i use a 16T pinion and the 20T pinion? i'm just planning to use my stock motor on it
manerdie is offline
Old 01-23-2009, 05:04 AM
  #810
steanlol
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all
Just thought i'd post a couple of pic's of my original pajero , will get some pic's up later of my crawler pajero
steanlol is offline
Old 01-23-2009, 05:09 AM
  #811
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL.. 7700kv in the 'Jero.. we need to see some video of that..
Quote:
ORIGINAL: sasse2323
Lunchboxer is offline
Old 01-23-2009, 08:22 AM
  #812
sasse2323
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My kit came with a 16 tooth. It only went about 10 miles per hour. Slowest thing i have ever driven. Until the mamba.
Old 01-23-2009, 09:50 AM
  #813
The Collector1
The Collector1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an extra Mamba that I havent used yet but I dont think I would put it in my jero, I like my slow jero if I want speed Ill use one of my other cars
The Collector1 is offline
Old 01-23-2009, 09:53 AM
  #814
lee172
lee172's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
steanlol, awesome rigs, and where were ther photo's taken, looks pretty high..
lee172 is offline
Old 01-23-2009, 09:56 AM
  #815
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nothing is wrong with the stock esc with a stock motor or a motor up to 19T, I have tried a similar esc with a 15T in a different car and it worked but it overheated.
20 tooth will give you more of a top speed than the 16 tooth
Old 01-23-2009, 10:10 AM
  #816
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I like the stock TEU-101 ESC in general...
Old 01-23-2009, 10:25 AM
  #817
manerdie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: The Collector1
so are you saying sir that it is better to use the 20 tooth than the 16 tooth pinion?
manerdie is offline
Old 01-23-2009, 10:42 AM
  #818
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you want to go faster and heat up the motor.. yes..
I'd only run 16T pinion in this rig.. but that's just me.. ha!
Old 01-23-2009, 10:48 AM
  #819
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It depends if you want to go fast and how fast, I dont plan on flipping and scratching the body so I use the 20 tooth but I still have good speed, I also use a heatsink on the motor, It doesnt get hot just a little warm
Old 01-23-2009, 10:59 AM
  #820
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You use 20T instead of 16T? So you do want it to go fast then... ha! I thought you want to keep it slow?!?
Old 01-23-2009, 11:51 AM
  #821
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry it is the 16T I tried the 20T its fast.
The 16t in the jero is is faster than my Clod which is not saying much since the Clod is stock from 1990 when I first bought it[:-]
Old 01-23-2009, 11:52 AM
  #822
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, just want to make sure!
Old 01-23-2009, 12:00 PM
  #823
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nah I have fast stuff I dont need everything fast, its no fun that way[8D]
Old 01-23-2009, 12:23 PM
  #824
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you still have yours?
Old 01-23-2009, 12:37 PM
  #825
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Me?! Oh yeah.. I have many Pajero at home... [&:]
Don't tell my wife.. [:-]
Reply
Display Modes
