RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Tamiya Pajero-Collective Build
Reply
Old 03-08-2009, 01:57 PM
  #951
The Collector1
The Collector1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tamiya Pajero-Collective Build
Looking good bok, how do those tires hook up?
The Collector1 is offline
Old 03-09-2009, 01:00 AM
  #952
Bok
Bok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Collector1! The high lift tires hook up pretty well on the rocks, with locked front and rear diffs I barely saw them slip. But they don't hook up well when climbing loose dirt and sand. Don't know how they compare with the stock tires as I put these on right after I completed my build
Bok is offline
Old 03-09-2009, 03:43 AM
  #953
manerdie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats was a great run bok..hahaha...i told you that place rocks...more trail runs and rally cross to come guys..too bad we didnt take pictures when we are climbing that almost 6 ft sand trail(formed into a mini mountain or scale mountain..hehehe)
By the way who can sell me a spare cc-01 spur gear? Mine got busted(because of my own fault) so i need one asap...thanks..
manerdie is offline
Old 03-09-2009, 04:18 AM
  #954
cornel4web
cornel4web's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how's that???...the trainy are pretty buletproof...which part you broke?
cornel4web is offline
Old 03-09-2009, 08:34 AM
  #955
manerdie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i opened the tranny case after a run then run it again, i think a loose debris went inbetween the pinion and spur gear after openening it...it does work but it has a cracking sound..
manerdie is offline
Old 03-09-2009, 09:02 AM
  #956
Bok
Bok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could you show us a picture of your tranny? Maybe something is just loose inside
Bok is offline
Old 03-09-2009, 09:04 AM
  #957
manerdie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nothing is loose, spur is damage a bit...i need to find some G parts
manerdie is offline
Old 03-09-2009, 09:08 AM
  #958
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you should open it up and make sure you clean everything out.. a lot of time the clicking sound is from a sand that got stuck between the teeth... so look for them!
Lunchboxer is offline
Old 03-09-2009, 09:19 AM
  #959
Bok
Bok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup I would try cleaning the gears and bearings inside the tranny. Use a toothbrush and soapy water to clean the gears. Don't forget to grease them when you reassemble everything.
Bok is offline
Old 03-10-2009, 06:34 AM
  #960
Bok
Bok's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Was able to work on the Pajero today. Replaced the sloppy lower trailing arms with aluminum ones from my CR-01. Upgraded the CR-01 to bent links, so I had these lying around Will tackle the upper arms next...
ID:	1154386   Click image for larger version
ID:	1154387   Click image for larger version
ID:	1154388   Click image for larger version
Bok is offline
Old 03-19-2009, 07:39 AM
  #961
HondaFun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I have one too, mine is the first version which i bought it in 1993. I have recently bought a new body kit (the original one is pretty much destroyed) and convert it into the low ride conversion set. It has full ball bearings, ESC, RS540 motor, lock diff.
Pajero are very strong cars. Mine is around 15 years old and runs perfectly.
ID:	1161056   Click image for larger version
ID:	1161057   Click image for larger version
HondaFun is offline
Old 03-20-2009, 01:49 AM
  #962
ramp4ge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My 'Jero.
Fifty-Five/XL5/"Wolfpack" 3000MAh.
Full bearings.
Full hex hardware.
Associated buggy front shocks on the rear, waiting for the fronts to come on. Apparently Tower only had 1 set. Got the AE springs up front tho.
Waiting on some Trail Docs.
Paint was actually a "prototype" and color-testing for this:
When my 10th scale H3 gets here.
ramp4ge is offline
Old 04-22-2009, 03:59 PM
  #963
cbs52
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got mine very wet the other day, so I decided to take it apart and clean it before any bearings seized. Took the receiver out of its balloon only to find that it was quite wet - ooops. Decided to get a plastic box to fit the receiver in to avoid this trouble in future - see the photos for how I fitted it. Also fitted my old Demon triple 17 turn motor to see how it goes - will find out tomorrow...
ID:	1185282   Click image for larger version
ID:	1185283   Click image for larger version
ID:	1185284   Click image for larger version
cbs52 is offline
Old 04-22-2009, 04:33 PM
  #964
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get some waterproof grease and put it on all the threads of the screws that go into the case and around the opening of the case
Old 04-23-2009, 07:37 AM
  #965
cbs52
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: The Collector1
Thanks, I will, or at least make a gasket of some sort and find a suitable grommet to seal around the wires. I am actually going to redrill the holes in the base as it needs to go back a bit to be more solid (and I got them in slightly the wrong place to start with). At the moment it's warm and sunny here, so there's no rush...
cbs52 is offline
Old 04-23-2009, 11:37 AM
  #966
cbs52
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, the Demon motor has noticeably less torque so there's less wheelspin and less acceleration from standstill, but it is noticeably faster at the top end. Almost too fast for the chassis really. On loose surfaces, makes it more entertaining as it is easier to drift and spin. Motor does get warmer than the silvercan.
cbs52 is offline
Old 04-23-2009, 04:01 PM
  #967
engineerjoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well, i guess I'll post up some pics of mine.
35T motor
sidewinder running on 4s A123 (13.2V) FASSSTTTT!!!
Losi Mini Crawler shocks in the rear for more articulation
pics are frome various stages of the build
added a snorkel
engineerjoe is offline
Old 04-28-2009, 02:36 PM
  #968
cbs52
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice pics engineerjoe, and what a great place to run! I see your bodyshell is looking like it has seen some action, but then if you are running it fast, it does tip over more as I am finding with a modified motor in mine.
Have resited the receiver box that I added to make it more stable, as you can see from the pictures below, before first then after. You might also notice that despite not wanting to get it dirty again, it is...
ID:	1188524   Click image for larger version
cbs52 is offline
Old 04-28-2009, 08:59 PM
  #969
Andyjk
Andyjk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey everyone, wow some awsome pics. I love the scale realism of this car.
Just wondering if anyone knows the part numbers for the stock wheels and tyres that come with the Pajero?
Any help greatly appreciated!
Andyjk is offline
Old 04-29-2009, 07:28 PM
  #970
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Andyjk, the part numbers are 0445516 for the wheels and 9805561 for the tires
Old 04-29-2009, 07:51 PM
  #971
Andyjk
Andyjk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh awesome thanks heaps!!!!
Andyjk is offline
Old 04-30-2009, 02:29 PM
  #972
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem Andyjk, heres a couple of pics with a working winch I just installed, the winch is controlled by the 3rd channel on my 3PK
ID:	1189642   Click image for larger version
ID:	1189643   Click image for larger version
Old 04-30-2009, 02:40 PM
  #973
Lunchboxer
Lunchboxer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL, that's pretty sweet.. how about a video of it pulling the truck up?! hee!
Old 04-30-2009, 02:42 PM
  #974
The Collector1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow you really want to see my crappy camera at work dont you? Ok but it will take a while since Ive never done it before
Old 05-01-2009, 02:01 AM
  #975
Andyjk
Andyjk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats awesome! I love the realism of this model. I have a DF-01 with Porsche Cayenne body and love it. I just installed a new ESC and Tamiya super stock BZ motor in it....goes pretty well! I want to see if I can get some slightly bigger wheels/tyres for it to give it some more ground clearance, thats why I was looking at the Pajero ones.....plus they look cool. haha
Here's a pic of the DF-01.
Andyjk is offline
Reply
Display Modes
