Dynamite Tazer 12T ESC
http://www.dynamiterc.com/Products/D...ProdID=DYN4927
Product Specifications
Forward:Proportional Forward
Reverse:Proportional Reverse
Brake:Yes
Time Delay Brake:Yes
Continuous Maximum Current:46amps
Input Voltage:4-6cells 4.8-7.2volts
Input Connector Types:Tamiya
Output Connector Types:Bullet
Motor Limit:12Turns
Momentary Peak Current:900 amps
Dimensions (WxLxH):1.25 (38.6mm) x 1.02 (26.2mm) x .888(22.5mm)
Weight:1.2oz (34g)
BEC Voltage:5v @ 1amp
Overload Protection:Thermal
Review
I got this ESC after my stock one bit the dust. I was a little worried buying since there were no review of it but I took the risk. I opened it up tested it then converted it to Deans. I installed in my Evader EXT with room to spare. I got it set-up which was a breeze. With the 15T motor I couldn't even tell a difference in temp after a 7-10 min. runtime. Locking out reverse is as easy as holding the button and restarting the ESC. I highly reccomend this ESC to anyone. (Even 1/18 owners)
Pros-
Super Small
Easy to Set-up
Cheap
Heatsink
Outboard Wires
Con-
6 Cells Only
Brake:Yes
Motor Limit:12Turns
Weight:1.2oz (34g)
Review
Pros-
Super Small
Easy to Set-up
Cheap
Heatsink
Outboard Wires
Con-
6 Cells Only
RE: Dynamite Tazer 12T ESC
I have one in a dark impact and it gets really hot in there too. I find it is not tolerant of batteries that are low in power at all, also when they say it will handle six cells they mean six lol It won't work with a 7 cell even if they are crappy tenergy or powerizers. I have a few duratrax that have like a 18-20 turn limit and they will run 8 cells no problem, but hey I figured maybe it's due to the tazer's tiny size. In a car like the dark impact with a tiny shell to deal with the size is a huge plus for sure, but I'd think it'd be pretty iffy running a higher end 12 turn motor without some sort of a fan or something rigged up.
