The Official Traxxas Slash short-course race truck
#3001
RE: The Official Traxxas Slash short-course race truck
I tried looking it up in the owners manual and it appears to be the code for low voltage detection but I have tried 3 separate, almost new, 7 cell batteries in it and they were all charged. Im new so this could just be something stupid that Im missing. Thanks in advance to anyone who can help me
#3002
The LVD is going off because it is for use with lipo, not NIMH. Simply turn off the LVD when using NIMH and you'll be good to go.
ORIGINAL: 54Slash4X4
#3005
Ive had that problem... wanna know what it was.... u wouldent belive it...
the Areial wire was unpluged
here have a look at mine, in this pic everything is connected correctly... the arial is the black wire, its a simple push on connection
Hey got a tim for u guys.... ever broken a areil????
here is a simple solution untill the new one arives
here is my current controller with voltmeter mod. ive got a TQi on order cant wait to get that.
#3007
Thanks for the help guys. Ive had the thing for 3 weeks so Im guessing Traxxas will replace whatever it is causing this right?
#3008
I spoke with Traxxas tech support and he said he thinks it just an issue witht he receiver itself so hes sending me a new receiver to try that. Heres hoping hes right
#3009
BC, CANADA
i just orderd a xtreme racing chassis for my sons truck.not the g 10
its the digital camo one
are they anygood? i have the outlaw on mine right now and i love it
when it gets here next week and i get it together i`ll let you guys know
#3010
My Feedback: (12)
hey guys, i am new to the slash forum and had a question. i see all these videos on youtube about slash 2wd's with 3s lipos and they are wheelie monsters. so i got a sky lipo 3300mah 20c 3s to put in mine. this thing flies....but no wheelies and mucho tire spin. i assume i dont need to have the slipper nut tightened all the way, or do i? it is about half a turn from close now. any suggestions on getting wheelies? thanks for looking
#3012
ORIGINAL: CUHRYTDUH
#3015
Stiffen up the rear springs, tight slipper is the way to go too.
mine will only wheelie on high traction concrete, or with different wheels
#3016
My Feedback: (12)
thanks for the tips, but i need more advice now. I went to run it and something broke. The pinion and spur spin with throttle but the tires dont move. I assumed it was the diff so i took it apart and dont see any visisble damage, but i noticed the output shaft that goes through part number2388x will spin freely inside part 2388x. I put 2 and 2 together and figured something inside it is broke. I got a feeling it has 50 gears and washers and bearings inside it so i would rather just replace it. Should it spin freely? thanks for looking
#3017
BC, CANADA
I just did one it's pretty straight forward ..it's got instructions with it.
If you open the big white round diff you will see you most likely chewed up some gears.
Dontbe scared its super easy
#3019
If u are holding the diff assembly if u turn one side the other side should spin the other way, or hold the assembly and 1 out put shaft tightly, the other shaft should not spin.... Don't be scared ofte diff... It's very basic. Honestly open it up and fill it with some 100wt oil...
#3020
Hey guys, Im looking for advise. I have a Slash 4x4 and am looking at the Tekin 4 pole 4600 or 4000kv. I had a CC4600kv and had terriable over heating issues. I know I can gear down, but I dont race or anything. I just want speed and bashing. Im using a Mamba MP esc with a 20c 3s lipo and 17/54 gearing. Anyone know if the tekin 4 pole 4600 or 4000 kv will have bad overheating issues with this set up?.
#3021
That should work fine. Go lower in KV if you had heat problems. get the 4000kv...
Save some money and get a toro $60, its what im running. Just gotta get it from china right now, no one has it in stock in USA. Mine came quick gobs of power and cheeeeap
Black & yellow body (me) and the red one are running this system. (sorry cant watch on mobile due to opening and closing tunes)
[youtube]http://www.youtube.com/watch?v=-p5mnJGMtXo&list=UU4BjallDupOD8przrBXl3zA&index=1&feature=plcp[/youtube]
#3022
That looks pretty good, thanks for your help. So youre running a 4000kv w/3s lipo and 17/54 gearing with out heat issues? May I ask about what your speed is?
#3023
I'm running 2s. No clue what speed. Much faster than velineon on 2s. I'm running a 14 pinion 54 spur. Lower kv and lower gearing if u have heat issues. I can hold my motor after a run so it's just warm
#3025
ORIGINAL: hound54
got my new chassis and tires
its a xtreme racing digital camo
and some trenchers
and some trenchers
