The Official Traxxas Slash short-course race truck
#601
RE: The Official Traxxas Slash short-course race truck
Well a 12T brushless is 3300kv. @7.4v that would be 24420rpm I believe. As long as the turns between brushless and brushed are similar kv values then this should give you a good idea. I didn't find anything on the Titan rpm's or kv.
#605
The P2K2 will be MUCH faster than the titan. You'll probably need to gear it a little lower to keep away the heat monster, but it will still be faster, and have more torque.
#606
MO
has anyone used this battery? i just want a battery to drive in the snow and rain. All my other packs are lipo and i want a cheap nimh pack.
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTJH4&P=ML[/link]
#607
ORIGINAL: fusebmx13
#608
MO
Yea i might try to re solder my ener-g battery and i also have a bunch of old 6 cells. But they wont have very much power. I just was thinking about getting that battery cause its very cheap for a 3600. Its just for a couple weeks until the snow melts and i can drive it on my brushless system.
#609
My Feedback: (12)
TX
ORIGINAL: FairTax4me
That's what I was guessing from the comment made comparing the Titan to a 3700 Kv Brushless. Thanks for the input. What do you think a good starting point would be? Should I go with the 90t spur, or drop down to a 16 or 17t pinion? Been a while since I ran electric. lol
Thanks again for the input.
#610
What size pinion is stock on the slash? I was thinking its 23 for some reason but now I'm thinking that's the optional one. (I don't know because I bought mine used from a friend with a 25 tooth pinion in it.)
And I think the titan is closer to a 3100kv motor.
#611
#612
Has anybody here happen to know if theres a really fast slash anywhere in florida?
Im trying to claim the name but i dont wanna claim it if i cant back it up.
Im not exactly sure how fast my slash is goin but it gets movin pretty fast, Considering its got a feiago 8L pushing it on 12 cells [>:]
#613
#614
DE
what would be a good weight of shock oil to just make the suspension a little firmer? also what weight comes in it stock?
#615
I don't think anyone knows what Traxxas stock oil weight it. At least, nobody Ive talked to knows what it is. But Id like to know that as well.
One thing you could try is switch to a 1 hole piston.
#616
NY
Hi Guys, looking for a few places that sell parts for the Slash. I guess I'm really looking for some places that sell upgrade/hop-up parts for all sorts of 1/10 scale vehicles. Exclude Tower for now, I know that one. I am developing an accessory for 1/10 scale trucks, but it is being tested around a Slash, so I need some links for places that might carry it. Thanks in advance.
#617
ORIGINAL: Always Dreamin
It's 19, and the 23 is the optional one. You could have easily looked that up.
#618
ORIGINAL: SupaMan89T
#619
2 questions, whats the best / cheapest motor to replace a titan that the stock esc can handle?
the other: whats the best gear set up to go faaaaaaassssssst with the slash with stock components?
#620
FL
I believe it comes with 30w all around. I changed out just the fronts with 45w. Gotta get it on the track and see how she handles.
#621
Just filled my diff 1/2 way OFNA diff lock and 7k diff fluid mixed together. Locked up pretty good allowing just a tiny bit of spin, enough to not stress the tranny. We'll see how it hold up. Running RPM narrow rock crawling rims with HPI Geolanders. I installed the hexes that came with teh RPM rims as they are smaller and let the wheels tuck in a bit more. So far on grass they work like a charm!!
Going to the track tomorrow to see how well it all work out.
#622
DE
what are some good brushless systems for the slash that are the same amount or cheaper than the vxl? or a good motor for the titan with stock speed control
#623
thats what i want to know a good motor thats faster then the titan but able to work with the xl 5, i put my mamba 5700 and SW esc in the slash for a week WAAAAAAYYYYY TOOOOOO FASSSST
#624
ORIGINAL: BuzzBomber
The PAPERWORK says 19 tooth, but mine, and most others at my race track, came with an 18 tooth pinion installed. Yes, I counted the teeth to be sure.
#625
ORIGINAL: misfit650
