The Official Traxxas Slash short-course race truck
#1252
RE: The Official Traxxas Slash short-course race truck
Your best bet is to see what other people are running and go from there. The owner of the track I go to is a sponsored pro so he know what tires works best on his surface.
#1253
TX
The owner of the track I go to doesn't ever race, hes more of a plane guy, so he has no idea. I'll ask around about tires next time I'm there, see what everybody else is running...
#1254
OH
slash good points? $200.00, toughest rtr rc you can buy, it's water proof, fun to drive, fun to race. i have raced, and bashed for over twenty years, i have trucks with $1000.00 plus put into them, and this slash is far more fun to drive than anything else i own. watch CORR truck racing on TV, if you like what you see, then go buy a slash. really this truck is more than worth the money. and you can run it bone stock in spec racing and it is fun. find someone that has one, run it for 1-2 minutes, then you'll want to go buy one. stock they are not the fastest, but the slash is just more fun and exciting to run than most other rc's.
#1255
Which part of the VXL motor should you check temps on?
Should it be on the can itself or on the plastic cover on the end of the motor?
I run in pretty hot conditions most of the time and check temps usually by hand on the motor can, but read on another forum that you should check the temps on the plastic cap.
I have purchased a PE Exotics temp gauge, and running 19/86 gearing on 2S lipo it gets to 185F on the motor can. I know that is in the proper range, but if i take a reading on the plastic it is much lower...
Where do you temp?
Where do you temp?
#1256
Take the highest reading, that way you know you aren't screwing it up. 185f is up there, 200 being when you really need to stop.
MadManAndrew:
Avoid the mamba motors in the Slash, they are too hot running to use effectively without gearing down to 15/90 or even lower. This is bad for efficiency, very bad.
Best mild setup by far is the Mamba ESC with VXL motor. The VXL esc is fine but if you are racing you need the adjustability of the mamba. A correct throttle curve can mean the difference between pissing all your power away in wheelspin out of a corner, and it hooking up perfectly and leaving the pack for dead. The VXL stays coolish and can pull big gearing happily.
If there are buggies running your track, I suggest you get some 17mm adapters and run buggy rims and tires. Then you can take tire setups from the quickest buggies.
Aside from that, get Traxxas or STRC alloy rear hubs, RPM arms, RPM towers and RPM front camber blocks and hub carriers. The RPM rear hubs seem to break quite easily on the slash compared to their other parts. That will make the truck very tough and keep it light with mostly plastic. You may want to look into some high quality Associated shocks or the Traxxas big bores. At the very least you will need alloy caps on the stock shocks.
MadManAndrew:
#1257
Don't use rpm parts they break just as easy as stock parts. I know have went through many sets of caster blocks and steering hubs cheaper to replace with stock and last just as long. Use flm shock tower they are more adjustable work great. If you want the castle mamba system use the 4600 you will be able to gear it using stock gearing with out heat issues.
#1259
hey guys ive been reading alot af this thread and ive decided to get a slash but i am wondering what would be the best battery for bashing and just ripping around at sand pits and in feilds also can you run lipo with the stock moter? if so which lipo would be best for run times but still have deacent speed
#1260
OR
ORIGINAL: Lilredmachine
#1261
OR
ORIGINAL: CosmoKramer
The brushless system eats through my nimh packs in no time. But can get long long runs with the LiPo. I get full power from the LiPo pack until the low-voltage cut off stops the truck, whereas with the nimh pack you lose punch as the pack wears down. Plus if you race, the weight difference is a plus; unless they make you add weight. I would def get another LiPo pack.
ORIGINAL: munro300
How much of a difference do you notice between the two? All I have re NIMH's but I want to get a 11.1v lipo when the snow clears, I guess I could try one of my heli batts but there only 2200mah.
#1262
in the 15 to 20 miniute range is a bit short 25 sounds good but do you
get longer runtimes with the vxl setup? how long do you think it would run with a 5000 mah nimh pack
#1263
Budget monty just use the stock parts cheaper to fix. Those are the parts I break tired rpm but the stock parts hold up better. Aluminum parts put the stress some wear else.
#1264
TX
Wow, things have changed alot since I had my EMaxx, the longest run times I had with it were 5 minutes...
#1265
TX
Is [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001319511&I=LXXCG5&P=K]this[/link] what you need to run buggy wheels?
#1266
ORIGINAL: MadManAndrew
#1267
AL
I'm looking to get a new radio to use with all my different rc stuff.
Which one do you think would be better The spektrum DX3R
http://www.spektrumrc.com/Products/D...ProdID=SPM3100
or the DX3S
http://www.spektrumrc.com/Products/D...ProdID=SPM3130
or the DX3.0
http://www.spektrumrc.com/Products/D...rodID=SPM20310
Which ever one I get will be the only radio I will buy for a long time.
or the DX3S
or the DX3.0
#1268
CO
any of you guys that are breaking the rpm stuff sending it back to rpm? splitting the rear hub that is hard to do. get your part fixed rpm warranties against breakage.
#1269
OR
ORIGINAL: lestatsghost
#1270
I've seen lots of people on this site and others commenting on how big and heavy this truck is compared to other 1/10 trucks and how consequently such and such upgrade, motor, battery, etc won't work. The truck is significantly larger in wheelbase etc., that much is fairly evident. However, I put both the Slash and my Stampede on a postal scale last night just out of curiosity and got the following numbers: Slash 4lbs, 13oz. Stampede 4lbs, 5oz. Both are with everything except a battery onboard. So we're basically talking a difference of 1/2pound(or 225grams for you metric types). Or, to put it in perspective, the difference is less than half the weight of a standard 6 cell nimh pack. Not an insignificant difference, but certainly not as much as I expected to find based on all the comments. Take it for what it's worth.
#1271
CA
Friday at work was hard ....hardly working ...so we busted out my RC gear and my FPV system. The Losi family (yep those guys that sold the biz a few years back) from across the alley came out to play. All it took was the FPV E-maxx and they where all over it..."Can I try it...."Whens my turn". I got some good video .
At the end of the parking lot there's a drainage ditch and sandwash that are a blast to play in.
Here's a video from my view as I drive it from the video feed from inside the shop.
[youtube]http://www.youtube.com/watch?v=L8-B1fdIl9w[/youtube]
#1273
CO
the reasons the weights are so close is it is almost the same as a pede. they changed the steering and base plate which are the big differences few other small changes were added, but thats why the weight is only slightly off.
#1274
#1275
The CMS motors are 'relatively' hot for the Slash. I mean they'll work, but to be honest having the motor sat at 185f every run is going to balls it up eventually.
Fact is, the Velinion is a more efficient, cooler running, better quality motor. The CMS motors used to be better but they have dropped in quality.
No sign of mine bending, and I've only recently stopped running my speed slash geared 31/76 at 60+ mph with the crashes that brings.
but it looks like I need to get the aluminum rears. Anyone bend them, or are they pretty bulletproof?
