The Official Traxxas Slash short-course race truck
#1802
RE: The Official Traxxas Slash short-course race truck
#1804
FL
Went last night and clocked my Slash with a radar gun...
Mods:
15/90 Gearing
MM5700
2s Lipo
ESC MM detuned all the way
34 MPH was my fastest run did it about 4 or 5 times.
My next move is to start messing with the ESC and 3s Lipo is on its way.
My temps on the motor dont pass 169.38 that was the highest reading i had after 30 minutes of W.O.T.
You guys have any suggestions for me on what I can do to get more speed?
Mods:
15/90 Gearing
MM5700
2s Lipo
#1805
170 is pretty maxed for that 5700...
New motor is the only thing you can do. You push that any harder you'll smoke it.
#1807
ORIGINAL: anders e
Why 15/90 gearing?
I have 19 or 21/86 and its way faster than that
Why 15/90 gearing?
#1808
FL
ORIGINAL: Lilredmachine
Any suggestions on gearing? i was thinking maybe 12 pinion? would a bigger spur be possible i am running 90.
#1809
MT
you know if you increse both gears....you're not really gearing up, lol. (depending on how much you increase each gear, etc.) Throw in the stock 86T spur, and that should push quite a bit higher.
Faster = Big pinion / small spur
Quick accel = big spur / small pinion
of course for the most part, the faster set up will heat up faster, and put more strain on the motor.
As for your question, 90T spur is the biggest you can use the gear cover with, and I think it's the biggest one traxxas makes for the slash(?).
#1810
ORIGINAL: boosteda4tq
On the Castle Website it says 200 degrees...and for the sake of just wanting to see what is the fastest MPH I can get i am sure that making one pass or two passes i wont fry anything if i tune it up a bit. I am making a Excel Data sheet once i am done with it i will post it up should take me about a month to get all the data in but it will pretty cool to see what each mod or tweak has done to get the Slash up in higher Speeds. I am taking everything into consideration from wheel and tire combo to gear sizes the temperature to even the settings on my ESC and other factors to try to get the best detail data.
I'm running a 2350kv XL motor with 80a esc on 4s geared for 75mph and it goes all day long without so much as a blip on temps. The entire setup cost me like $160. And it'll be more powerful than any mamba max motored anything anywhere.
#1811
my car feels more sedate on 18/86 then when i was running 18/83
should i go back to 18/83?
ore should i go up a tooth on the pinion?
#1812
FL
I agree with you on buying a new motor and i am looking for one i am just not in a hurry to do so i dont mind messing around with this setup for a while.
#1815
MN
Changing from 90 spur to 86 only adds around 1.2 mphs , now changing a tooth on the pinion is a little more drastic around 3-5 mph. Spur sizes are mainly to fit more variety of pinion. On page 67 or 66 someone posted a relative-speed calculator that you can play around and see how much a tooth here and there changes.
#1816
PA
i need help i got a 14t speed gem in my slash the pinion size is 16t and it is runing at 250deg. with stock spur gear i need help to cool the motor
#1822
MN
try a 90t spur and see how it goes. it cant hurt anything. i used 19t pinion and a 90t spur with my 12t titan and the temps stay down
#1824
CO
i have a question, whats a good replacement motor for the slash that will be about the same speed as the stock motor? (a little better acceleration wouldn't hurt ether) i am thinking the reedy 17t http://www3.towerhobbies.com/cgi-bin...&I=LXMUN9&P=ML would this motor work? also what are some good upgrade shocks that dont leak and have better dampening?
