RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
waterproof brushless speed control?
Old 04-15-2008, 11:54 AM
Ja55
Default waterproof brushless speed control?
does anyone make one? if so, where can i find it?
Old 04-15-2008, 12:13 PM
engineerjoe
Default RE: waterproof brushless speed control?
aquacraft
http://www3.towerhobbies.com/cgi-bin...?&I=LXMYB8&P=Z
what voltage are you running? what motor?
Old 04-15-2008, 06:02 PM
Ja55
i''m not sure yet, i''m lookin for one before i go and buy a truck.
Old 04-15-2008, 08:37 PM
kistner
My Feedback: (10)
kistner's Avatar
waterproof: http://www3.towerhobbies.com/cgi-bin...?&I=LXRXX6&P=7
Old 04-15-2008, 10:17 PM
MahnkenVille
Will that last one work with the Sidewinder motor?
Old 04-17-2008, 11:04 AM
ElectricGuy007
This might work...I cannot say but people have tried and it worked out..
You can find it at home depot or Lowes.
Old 04-17-2008, 11:06 AM
Lunchboxer
Lunchboxer's Avatar
LRP claims it is waterproof, but it is really not....
I sent one in for repair before.. they gave me a new one... at least they stood behind their product.. ha!
Old 04-19-2008, 08:08 AM
Ja55
is there anyway to waterproof the traxxas VELINEON with out it over heating? a guy at my hobby shop said something about putting it in a case?
Old 04-19-2008, 09:24 AM
rcluke
rcluke's Avatar
how about, baloon it, aka put it into a baloon, (i have also seen someone put it into a condom [X(])
Old 04-19-2008, 04:31 PM
MahnkenVille
if your gonna balloon it, make sure to give it an air hole or two, otherwise it won't be able to properly cool.
What I did (for my old XL-5 ESC) was cut a hole slightly bigger than the footprint of the ESC into the lid of a small ziplock container. Mount it by popping holes in the lid where nearby screws are and putting the screws through the holes, holding it down. Face it bottom-up so you can attach and detach the container part, and cut small holes for wires. you have to make the hole in the lid a bit bigger than the ESC because it needs air to cool.
Old 04-19-2008, 05:43 PM
nitrosportsandrunner
nitrosportsandrunner's Avatar
i thought the problem was that brushless motors are not waterproof, unlike brushed.
Old 04-19-2008, 08:08 PM
mycarisaser
mgm esc have a coating over the curcuit boards to make them splash proof. I've had both of my 160amp mgms under water many times without issues. Also the new Castle mmm is waterproof.
I havent had issues with my motors from water either???
Old 04-20-2008, 12:46 AM
MahnkenVille
I had to send in my Sidewinder ESC recently, castle said even though I drove it through a puddle, it had a silicon coating over it like mentioned above. They covered it under warranty because water shouldn't have penetrated the coating.
Old 04-20-2008, 10:42 PM
snellemin
snellemin's Avatar
Look into Mtroniks brushless ESC's.
Old 09-03-2008, 07:46 PM
boomchank7
boomchank7's Avatar
Does anybody know if that aquacraft esc has reverse? It doesn't say on tower or aquacraft's website. I'm looking for something brushless and waterproof that will hold more than 7 cells that is within my budget. I'm looking to spend no more than $170 or so for a brushless ESC and Motor to go into my Axial AX10. If that's not do-able, that's cool, I'll just have to save some more $$. I just figured w/ all the stuff they have for boats and cars I just may be able to piece something together. There are all the waterproofing techniques which I'll employ as well, it's just that if the manufacturer calls it "waterproof" they gotta honor the warranty, ya dig?
Old 09-03-2008, 07:59 PM
boomchank7
boomchank7's Avatar
It doesn't necessarily have to run more than 7 cells, but the specs of the LRP said 130watts at 7.2v. That's kinda weak, right? I'd like to have something that will run strong in a bigger vehicle like the Axial.
Old 09-03-2008, 08:17 PM
Lunchboxer
Lunchboxer's Avatar
The LRP is meant for only up to 8.5T / 10.5T BL motors.. (depends on whether you go for the Pro version or not)
8.5T isn't too slow..
Old 09-03-2008, 08:39 PM
boomchank7
boomchank7's Avatar
Anyone else notice that the manufacturer says that the esc is waterproof but they never say about the motor itself. Anybody know for sure. I apologize for all the questions, but I've googled this stuff for a couple hours now and I just can't quite get a clear idea what I need. I was gonna just say screw it, I'll get the LRP combo at Tower, but then I noticed that about the ad listing. They never really say whether or not the motor is waterproof. So, basically what I'm getting here is that finding or improving a brushless esc is not the problem, it's finding a truly waterproof motor. []Right?
Old 09-03-2008, 10:44 PM
Lunchboxer
Lunchboxer's Avatar
The LRP ESC is not waterproof either..
Old 09-03-2008, 11:52 PM
boomchank7
boomchank7's Avatar
How about the Aquacraft ESC mentioned above w/ this motor? http://www3.towerhobbies.com/cgi-bin...XMYF2&P=Z#tech They are run together in a boat called the Super Vee 27 if that helps. Also, anyone know if that ESC is reversible?
Old 09-04-2008, 12:12 AM
Josh222
A boat esc won't be good in a car, If I remember right they are like plane speed controls and have no reverse or brakes. All the Castle ESCs also have coated boards and I haven't had any issues with them getting wet in snow, rain and slush.
Old 09-04-2008, 12:26 AM
boomchank7
boomchank7's Avatar
You'd think I'd just go buy a boat by now, huh?[8D]
Old 09-04-2008, 12:39 AM
boomchank7
boomchank7's Avatar
I just wanted to put something together that would shoot rooster tails in the mud, man. For real, I'm in central Illinois. Muddy trucks is what we do. I'll more than likely keep it simple and go brushed.
Old 09-04-2008, 09:55 AM
kistner
My Feedback: (10)
kistner's Avatar
you could always use one of the cheap hobbycity brushless motors, at $25-30 it might be the perfect mud motor, if it burns out, well it was no more expensive than a brushed, and maybe it won't burn out at all. I have a turnigy 3300kv I got from there, decent torque, does NOT run hot (geared conservatively) and due to the low price I will probably run it in the snow this winter.
Old 09-04-2008, 12:46 PM
e123
ORIGINAL: kistner
Wow those are some cheap motors! I know almost nothing about brushless but I want to switch my truck over. Which motor did you get?
