THE Official Traxxas E-REVO Thread
#276
RE: THE Official Traxxas E-REVO Thread
can anyone lety me know if there is any screws holding the tranny casing down to the chassis? i'm wondering particlarly about the part of the tranny facing the front of the truck. Do your trucks casings have a lot of wiggle to them? Thanks[8D]
#277
ORIGINAL: pilsner6981
#278
NC
Question for all of you. Would you all pay $320.00 usd for a 9000mah 4s 30c lipo that would fit in an e-revos stock battery trays? If so check out the elites 4500 4s 30c lipos they look as they will fit. I cut a block of wood just a hair larger than the given specs to see if it would fit and it did. Even if they can only handle like 20c its still would be the highest amp and capacity lipo on the market that would fit. That might be my next lipo(hour runtimes hear I come)
Just thought I would share
http://www.cheapbatterypacks.com/mai...an=ELT&cat=E30
#279
ORIGINAL: xxSLiMxx
there should be x4 screws holding the tranny on.
#280
ORIGINAL: mycarisaser
#281
anyone have pics they can post? can't figure out where these screws would go?
ORIGINAL: xxSLiMxx
#282
NC
ORIGINAL: xxSLiMxx
$320 for a snigle 4S lipo seems a bit steep
Its $310 for a max amps 8000 4s set up and it only 10 bucks more for the elites and you get alot more avalible power and 1000 more miliamps. I see no down side!!!!!!!!
#283
ORIGINAL: xxSLiMxx
Its the 4 screws that are in the middle. How do you not know where they would go?
ORIGINAL: xxSLiMxx
#284
hmm i think i mean the motor mount on top of the chassis. the big black base in between the receiver box and the esc. i need to know how that is held down to the chassis. it seems to wiggle around a lot. There is a burning electrical smell coming from the truck i think i burned out a motor too.
ORIGINAL: xxSLiMxx
ORIGINAL: xxSLiMxx
#285
ORIGINAL: xxSLiMxx
Take a picture or find one on the web and circle it. Because the motor mount its attached to the tranny gear box by 4-5 small flathead screws....theres 4 or5 holes that line up with the tranny....should be self explantory.
ORIGINAL: xxSLiMxx
ORIGINAL: xxSLiMxx
Is this the part that you mean???
#286
#287
PA
#288
pilsner6981, the 1st pictures i posted are the right ones, theres 4 screws that go in the bottom of the chassis and hold the tranny on. Make sure you have all 4 screwd in tight, you dont want your tranny wiggling around it could cause alot of problems with your spur gear, drive train, might mess up your motor too if it get bad enough.
#289
NC
ORIGINAL: vge
personally i would never pay that much for one battery. hell a little more and you can buy another erevo.
Its hard for me to swallow too butif you look at all the people that buy the maxamps 8000s its only 10 dollars more. Still a little out of my price range at the moment
I was just trying to find a better alturnitive that gives longer runtime and more power.
#290
ORIGINAL: vge
#291
NC
I wont buy another maxamps battery b/c of not getting what I payed for but alot of people do.
I was going some old paperwork getting ride of my old lst2 stuff and found a reciept for a hyperion 20c 5000 5s that I bought a few years back and it was $320.00 man lipo prices have come down quit a bit.
#292
PA
it's funny you just mentioned those maxxamp 6000 packs. someone is on ebay right now selling them as factory refurbs for $110 bucks!!!!
#293
ORIGINAL: xxSLiMxx
Thanks for the info dude. those screws are really tight.
Unfortunately i didn't mean the tranny. i meant the part which i circled in the pic i posted. i was wondering how many screws hold that piece down and if wiggles for you or anyone else for that matter. Thanks again[8D]
#294
NC
Slim
ORIGINAL: xxSLiMxx
#295
CA
hey guys now many lipos can the ex2 take in stock form.
I think i heard 2s cause of the no low voltage cut off.
If so in order to run 3s or higher will i need a new esc, such as the mmm or novak.
#296
NC
The evx2 will take TWO 2s lipos= a 4s lipo and you do need a lvc. The mmm will take up to 6s lipo and the novak hv will only take the same as the evx2 but the new pro has a lvc built in
#297
IL
#299
ORIGINAL: Snaut Rocket
okay when you say lvc are you talking about a bec or is that a totally different thing.
