brushed VS brushless motor
RE: brushed VS brushless motor
Brushed motors need comm cuts and brush replacement every 5-10 runs.
Brushless just need a good oiling every now and then.
Plus brushless is more efficient. And can go real fast.
ORIGINAL: divine_13
No.
ORIGINAL: blitzskiff
okay then wouldn't brushless be cheaper then brushed? [sm=confused.gif]
okay, that explains why may electric cars seem to be getting slower as the day goes by [&o], thanks for the help
can the speed controller in the e-revo handle brushless motors?
ORIGINAL: Contra_
I know it depends on the car, but about how much does the brushes cost to be replaced every 5-10 runs?
Brushless motor ESCs are totally different to Brushed ESCs as the motors work differently. However brushless ESCs sometimes work with brushed motors, Castle Creations MM esc for example, will run both brushed and brushless motors. However it requires the ESC to be set in a different mode, and failure to do this will destroy the ESC.
Brushless ESCs are far more complex, hence the reason brushless ESCs are almost always more expensive than brushed ESCs, and hence the reason that releasing an RTR brushless vehicle is a big deal.
ORIGINAL: Lilredmachine
No, the speedo in the E-revo is a bog stocker EVX-2 for the two brushed titans that come with the E-revo.
arrrgh im gettin a 10 turn brushed today should i get a 12.5 turn mototr instead? i know the powerband in the brushed is better
ORIGINAL: DriftingDragon
i found a used brushless caslte 4800kv for 60 bux at my lhs but is was a steal but now i need a mm
what is the difference between brushed and brushless motors? thanks
Brushless no comm lathe needed, and the motors last a while, the only thing you need to replace is the front bearing every 300 runs.
ORIGINAL: muti369
a com lathe with a motor can be had for about $120
BTW my dad has a bunch of scale train how come the brushed motors in there do not wear out?
great another thing i have to buy[:@]. does anybody know a good,cheap, 1/8th scale brushless motor system?
ORIGINAL: muti369
yeah the reason i am asking all these question is because i am debating about getting an e-revo when it is released but i hate the titan motors they put in there. I really do not want a mamba max or Nue motor because i can't spend that much money[:@]. Will the side winder work for that? i really do not care or want anything to go above 30 or 40 MPH. i am driving in parks or my yard most of the time so anything above 40 is over kill.
