drive me mad
drive me mad
on my lrp a.i esc i pulled a wire out of my deans plugs and the wires are already short i cant solder it back on im not a bad solderer but im not that god either any suggestions on what i shoud do? im pulling my hair out with stress (joking) i never break parts just electronics
RE: drive me mad
If there is still wire then you should be able to solder to it. Just add a little more wire to it so its not so short. Put the deans on the new wire first.
Just tin the 2 ends that you want to solder together then put a dab of flux on them and put the 2 wires end to end and hit it with the iron for a second or 2 and tyhe 2 wires will be soldered together. Then jus hit it with some electrical tape.
Soldering wire together in a tight spot is easier than trying to do the deans in a tight spot.
RE: drive me mad
everything is so close to..me esc my homemade roll cage its so tight ive managed to get a new piese on to lengthen it the iron is heatin up now *preys*
RE: drive me mad
Kind of difficult to see what you are asking us? You are unsure if you should solder the dean's back on? I would if I were you, find someone who can solder and it should be a breeze for them and take no time.
How did the Dean's plug come off before? A good solder joint is near impossible to separate.
RE: drive me mad
You should remove the electronics that you are soldering from the vehicle.
Also take some time and watch this: [link=http://www.youtube.com/watch?v=XYhmzY5wQAA&feature=related]How to solder Deans Connectors[/link]
RE: drive me mad
Ya you should deffinetly remove the esc from the vehicle to do soldering work. You could end up hitting something with the iron andcause more problems.
MO
RE: drive me mad
Another vote for removing the ESC.
Make sure you have a nice soldering iron, and a good tip. A marginal soldering setup will not work for Deans. Some can get cheap irons to work, I can, but not well. I have used various high end soldering stations at the track, and those things make soldering a breeze.
RE: drive me mad
yep my pop soldered it for me..he did the best job but i seen a vid on youtube the guy makes it look so clean fast and easy[X(]
RE: drive me mad
ORIGINAL: MF2MM5700
