What the heck is going on with my Tsunami?
Hey there i brought in a Redcat Tsunami and did the brushless swap....im running a fully chaarged 3000 Ni-Mh battery and the problem is when i punch the throttle is shakes and twitches(starts and stops) ...my controler batteries are good ,i even changed the crystals in case one may have been faulty.Can anyone help me.I m going to try to upload my video and maybe someone can help if not i can send it to your email if you think u might have an idea.thanks
RE: What the heck is going on with my Tsunami?
Sounds like the Battery cant handle the amperage the motors trying to pull. Thatss why most switch to lipo when they go brushless.
Well thats kinda what im thinking...its funy redcat doesnt let you know this and furthermore even sell lipo batteries..well thats a pi$$ off,who am i gonna sell a brushless angine and esc to without a lipo and god knows the lipo batts are not cheap
ON, CANADA
3000mah nimh's?, there probs just your everyday cheap 3000mah batterys They woulda died on a 17t, and your brushless system is barly even reconizing them, aka Cogging badly, go lipo, you'll be rippin
NJ
Did you use the Redcat 3000mAh battery because those don't work. Firstrc, said he tried them and it didn't even work. He's now getting on demand wheelies with a 7 cell ener-g 4600 http://www.boomboombatteries.com/pro...7c_traxxas.htm
I'm not familiar with the Redcat system, but Lipo is not necessary to run brushless. My buddy runs all NIMH in his rustler VXL and it cooks along just fine. He runs everything from cheapos to Venoms to Maxamps to GP's and they all work fine. Maybe the Redcat system demands more amps? I don't know?
Are the batteries in decent shape? A decent brand? What kind of connectors are you using, because if they are Tamiyas then you need to dump them for Deans.
Yeah the redcat 3000 mah do not work with the brushless. Nick at redcat verified this and gave me credit for the ones I bought.
I have the red cat brushless system. Using nimh battery
With a venom 3600 battery, 10 minutes then after it starts to chug when the battery is low.
Venom 5000, around 20 minute use then it weirds out.
With the stock REDCAT 1800mah battery about 4-5 minutes use then it dies.
What kind of charger do you have? Maybe the cells are damaged in your battery. How many amps do you charge your battery with? Is you battery old?
ORIGINAL: islandturbos
If the 3000 mah battery is a redcat battery it will not work no matter what the answers are to those questions... It is a known problem (known at redcat) that the redcat 3000mah's do not work with the redcat brushless.
ORIGINAL: firstrc
The only redcat battery i have is the stock 1800mah battery and it works with my brushless for a few mins
IL
What brushless system are you using? My brother uses a stock novak system and gets at least 1/2 hour from 3000mah venom and even radioshack batteries.
It's down to the system and the condition of the pack. A poor pack that has been treated badly over it's life or has a defect from the factory may not even run the system. No doubt NIMH can propel brushless, but it's a whole different world from Lipo.
ORIGINAL: firstrc
Yeah the 1800's will work but only for a few minutes as you said. The problem is known so far only with the 3000's
Hey man go get a 5000 battery, i just got one i get 20 minutes of play out my red cat brushless, kit and that is almost full throttle all the time drifting. And if it still cut outs even with a 5000 battery you may have bad connection, our controller our receiver problem.
NJ
I'd highly recommend the tenergy propel cells. I would NOT recommend the other tenergy cells as they are very poor for brushless. I built 2 packs out of propel cells in a 6 cell SxS. I'd also recommend deans connectors which will help with any resistance.
[link=http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1992]Propel 6 Cell Stick[/link]
[link=http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1991]Loose Propel Cells[/link]
pede- I am an novice and just bought my son his first rc.. the volcano EPX electric brushed (now after reading for a few days thinking should have gone brushless) and needed to know about upgrading my battery to get more than 10 min run time. What current battery do you recommend (same propel from this 2008 thread?) and do I need to buy a new charger? I only have the 1800 and charger that came with the truck.
MA
http://www.hobbycity.com/hobbycity/s..._hardcase_pack
Here is the best Lipo battery on the entire web for only $33.95. The run time, quality and punch is far superior to that of cheaper cells that some companies try to pass off as being good, when in actuality they are subpar. I would stay away from Tenergy cells, as i have experience with them first hand and I will tell you that I was very disappointed. Maybe things have changed, but I personally wouldn't chance the risk of ever buying them ever again. The Lipo pack that i pointed you out to is basically the same as the SMC Lightning Volts 4000Mah pack, but for a fraction of the price. The quality of the cells are right up there with even Team Orion, but much better for the wallet. If your not happy with the pack, I will personally refund you the money out of my own pocket.
MA
ORIGINAL: pickarw
Thank you all.
Gman1, what kind of run time do you think this battery delivers?
Thank you all.
No, problem my friend. The 4000 Mah depending on the application it's being used for will give you run times from anywhere between 30-45 minutes. It's a quite impressive battery for sure and as i said before, you won't be disappointed with it. If you have anymore questions, just let me know
