not only for rock crawling. axial AX10 Rock racer
AZ
well, im going to get one of these after a wile, but its not going to be a rockcrawler, it going to be a multi purpose vehicle. mostly for mud.
http://www3.towerhobbies.com/cgi-bin...I=LXTZW2**&P=7
Banned
NY
RE: not only for rock crawling. axial AX10 Rock racer
i think you can. head over to rccrawler.com and read some axial threads. (i bet you that i will get banned or this post will be deleted, because iam posting a link to another thread.)
SK, BANGLADESH
that rig is SLOW SLOW SLOW
very capable for crawling, but if you plan on bashing at all I wouldn't even bother with it
ON, CANADA
I agree, from what I have seen the gearbox gears the motor down too much for it to be fast even with a modest motor
I just picked up a wheely king 4x4 for the same purpose and find it great, of course it will need some modding as may the ax-10
What I like about it is is it reasonably fast while having lots of torque on just a 27t motor (I suggest switching the stock one)
Another advantage is its about $100 cheaper and the one without electronics if you have your own or would like to use sumthing better then included as I got is only $135
http://www3.towerhobbies.com/cgi-bin...=LXRSJ2**&P=ML
AZ
well this would require hardly any modification compaired to the wheelie king.
i wil be running these tires for the mud, and the stock ones for every were else
http://www.imexrc.com/servlet/the-28...L-TIRES/Detail
also a good video of one
http://www.youtube.com/watch?v=YEWCLbKgthU
ORIGINAL: sloppyG
StampedeKiller, get yourself either a nice 19 turn, 23 turn, 27 turn, or 35 turn motor if you plan on mudding with this truck. My recommendation would be a 27 turn motor, and put some high voltage to it (8 cell Sub-C pack, like an 8 cell Ener-G 4600). Mess with the pinion size until you are still getting really good torque but alot of wheel speed. It will be a very zippy little truck, and will be a great mudder. And be sure you lock the front diff too, as it comes with the front diff open.
AZ
thanks for the suggestions jolly roger pirate, but i dont really want to have that big aof a battery, also with the front end, is their some way i could make it a limited slip differential?
I have never heard of a mud truck before. Sounds like your blazing new ground Killa[8D] I am buying a AZ10 for rock crawling but if i feel like getting it dirty I will take it in the mud sometime. Not that we have much rain in CA or AZ.
ORIGINAL: Stampede Killer
SK, BANGLADESH
just go lipo
the battery placement on that truck is very high, and with 8 nimh cells it'll be very tippy with that much weight placed up so high in the chassis
ORIGINAL: sloppyG
just go lipo
just go lipo
SK, BANGLADESH
under the battery tray is where the ESC and receiver are,
he can mount the bats over the axle, but that requires some fabrication or buying the bracket from axial
