i did a small jump with my rustler vxl
and i after..my rustler doesnt work..the motor is ko? why after a jump i cant advance..
what s the problem? electronic ko?
RE: i did a small jump with my rustler vxl
is it turned on jk
any wires loose on the ESC?
it could be one of traxxas's shoddy soldering jobs in the ESC (but isnt the VXL developed by novak?) that i have heard people wine about for ages[&:]
shaun
shaun
IL
Is the motor still turning? If so, I had a similar experience after a jump. Make sure the motor itself isn't loose such that the gears aren't touching.
Jumps tend to slowly loosen screws, make sure your motor is close enough for the pinion and spur to touch each other, make the mesh correct, and tighten it!
The engine is squeezed(tightened), everything is OK, but the engine turns(shoots) not, it messes around it turns(shoots) half a second and it stops(arrests). I am done. I believed that the electric were reliable
not sure, but if the problem is the ESC(electronic speed controler) then you can get it replaced by traxxas for $0. i just sent mine in, about 10 days ago, and a new one will be here in 2 days.
when you say "but the engine turns(shoots) not" do you mean it will not turn when you pull the controler trigger? if the motor will not move when it should, then i would say the ESC is the cause. the place where the motor wire plugs into can come loose from the electronics inside the case. it will still be held in by the rubber seal, but not transfer power to your motor.
We either need to get this XavierG kid Rosetta Stone language learning English software, or we need someone on this thread who can speak German or whatever language he uses over there......
ORIGINAL: nitrosportsandrunner
thanks
ORIGINAL: Krawlin
Andrew
ORIGINAL: andrewtexas123
lol don't they speak Swiss in Switzerland? cause that's where hes from or am I making a fool of my self?
Andrew
ORIGINAL: Krawlin
Andrew
NC
sound to me like he's not used to the power.
He said it takes off, then it stops. Probably letting go of the trigger 'caus he's scared.
www.traxxas.com
here is some info
Traxxas
1100 Klein Road
Plano, Texas 75074
USA
Traxxas U.K.
P.O. Box 1128
Winterbourne, Bristol
BS36-2SH, England
Phone: 44-117-956-1002
Fax 44-117-956-1121
if you call, they will tell you to send $45 with the esc. do not. just send the esc and they will replace or repair. they have really good service center.
here is some info
Traxxas
1100 Klein Road
Plano, Texas 75074
USA
Traxxas U.K.
P.O. Box 1128
BS36-2SH, England
Fax 44-117-956-1121
My Feedback: (8)
CA
Yeah, with me it was the ESC plugs, I got so fed up with the ESC shutting down in the middle of the track (which is also very embarassing) I replaced the VXL system with a mamba max and a trinity brushless motor.
ORIGINAL: chippythekid
A hung brush can cause the motor to get jumpy and cut in and out.
my friend has the same problem with his truck i will tell him to send it out
Sorry sent that last one from my iPhone. I landed upside down and the wires going into the speed control broke off. So Im going to send it in to Traxxas this week.
