A123 on SC-15
A123 on SC-15
Would it be alright to use a A123 4600Mah battery on the SC-15 Stock ESC in E-Firestorm? It doesn´t require a LVC and is only 6.6V.
(Would it cause a thermal nuclear explosion?
Rgds,
Rgds,
RE: A123 on SC-15
no way... an explosion from a A123... lol ... they are the most secure batteries out there... they don't need a LVC... and 2s configuration... try 3s... is only 9.9 volts... i use A123... in 2300mah sxs... 3S... no need for a 4600... extra weight... zip charging them... 15 minutes of run... 10 minutes of charging... you will love A123... a lot of power...
