help with getting my car on the way need big help
My Feedback: (-1)
ok this is what it is im new to this cause i was jus serfing the internet and say this rc drifting i wanna get in it but donno how.
im 16 lookin all over the place for the hbi cars and yes i found them but way to much moula then i found a site it called(http://www.rcplanet.com)
and the rc was only $77.96 but the only thing it dosent come with a radio system, battery and charger and i need help?
i want to jus buy the car then buy the rest of the stuff but i dont know what to buy im goin 2 give u guys a link to the page an im lookin for any suggestionson what or where i should go frmo here
this is the rc i wanna buy
http://www.rcplanet.com/ProductDetai...10763&CartID=1
so what should i do plzplz help sum1 plz rite me a step by step of how i should go about getting the rc and actully being able to use it if i decide to order it?
IA
RE: help with getting my car on the way need big help
Well it tells you what you need right there, remote + servo, batts. , charger and and esc, get all that stuff and stick it in there, minus the charger haha. But i would recommend a RTR (or ready to run) car for a beginner.
My Feedback: (-1)
lol ok so jus go with one rtr and work from there and what if i want sumtin a bit more faster then jus the motor they have in there what do u recomend and those hpi rc are they battery packs or jus reg batteries they take
TX
They are battery packs like this
http://www.rcplanet.com/Trinity_Refe...p/tri20216.htm
And yes you should go with a rtr like this
http://www.rcplanet.com/HPI_RTR_Spri...Z_p/hpi761.htm
You will need paint, a battery, and a battry charger
http://www.rcplanet.com/SearchResults.asp you can go to the bodies and paint section for answers there.
battery charger
http://www.amainhobbies.com/product_...ducts_id/26105
and if you want to go faster then all you need do is put in a lower turn motor like one of these
http://www.rcplanet.com/12_14_Turn_Motors_s/859.htm
And if you dont want to drift any more all you need to do is change out the wheels and tires
http://www.rcplanet.com/Venom_26MM_S...vnr1045mc1.htm
you will need to buy two of the pre mounted rims and tires
battery charger
My Feedback: (-1)
wait so the rtr done come with batteries or they do and do i have to buy a batteri chasrger or does sit come with one
My Feedback: (-1)
and witch motor would be the best if i want to drift and use it for races witc one would help the car go its fastes
PA
Well, the first thing i'd do is get the kit you want. I'd recommend an RTR cuz that kit will have the majority of the stuff you need, thus more pricey. I'd work on getting the kit First before worrying about the motor, tires, or anything else. After you get everything you need, Charge the batteries and let er' rip!! After running the car you'll be able to tell if you want more speed/torque.
For Drifting usually you aren't going as fast as regular bashing around because the wheels are spinning loosing traction. Some people to save money, use ABC tires which are really just circular piping(fit to rim size) to get the Drifting affect. Or buy some drift tires, whatever money allows.
For drifting though with rubber tires, you'll usually need a Bit more Torque(To break the car Free into a slide).
Drifting and Racing though Unless its a drifting Race, are two separate Races all together. For Drifting your Loosing traction, while Racing(Street/track Racing) You'll want AS MUCH traction as possible. It's all kind of Trial and error figuring out the best setup for what you want to do.
Pick up, or save up for an RTR, Buy a couple diffrent sets of tires and test em out. We really cant tell you what to get, it's all up to you, all we can do is give you our Suggestions. You'll get it though, Just Pick up an RTR, and we'll help you Get it where you want.
