Rustler Help
MT
Rustler Help
Help me figure out what is wrong with my sons Rustler. We went and set up a track and about 5 min into it his stopped running.. The steering still works but when you give it gas it dont move.. Would like to figure this out but not sure what is going on. The ESC is on but no power to the rear... What can this be...
RE: Rustler Help
ORIGINAL: MTboy
As guver stated if you have no power to the motor then it is upstream from the motor as in possible esc. If you have power at the motor then you may have a brush that is stuck or motor that needs cleaning or replacing. You need to be sure you have a charged battery also.
MT
RE: Rustler Help
Well the wiring looks good. Used a new fresh batt and still just steering. Evven took the ESC and reciever out of the WK but still no go.. You think it's the motor???/
RE: Rustler Help
i have a Rustler and it has done the same thing before. in your users manual there is a section that explains what the blinking codes mean on the esc. so when this first happened i just checked the blinking signals and then looked to my users manual. it had shut off due to over power protection. anyway, it always shuts off like that with my Venom battery but with my losi battery (both LIPO) it will run for 30 minutes. so i am not sure if you have already torn down the car but my guess it is just your ESC trying to protect either the car or your battery. i think these ESC's are a bit overly sensitive but should this continue to happen i was told by one hobby store to call Traxxas and they could help/explain what to do. good luck.
RE: Rustler Help
ORIGINAL: MTboy
TX
RE: Rustler Help
If it is a VXL the motor terminals on the ESC have been known to break loose internally and cause this problem. I had to resolder the connectors in the ESC because this happened to me a week after purchasing the Rustler. I have not had a problem since!!
MT
RE: Rustler Help
Ok so I tried everything you guys said. The Motor is shot... ESC works with my WK motor but for some reason the Rustler stock motor already burned up...[:@]
Ok so now I need a new one quick..lol Would like a good motor that will last and not to much money.. Any ideas for the Rustler? Links would help...
CA
RE: Rustler Help
I would look at the Team Checkpoint Money 19t motor. get 20 off 50 if you are new to tower and you get 2 extra sets of brushes and a comm stick for about $60.
RE: Rustler Help
helping in a traxxas thread chrisrc?? that's different
when my VXL motor blew up i had to use a titan 12t for a while (had a new one lying around)
it was broken in with the water method and i ran on 7 cell nimh geared 19/90.
i had a problem with the brush getting hung up a lot.
look at the rear of your motor and are both brush arms in the same posision?
if not then get a small stick and push both brush arms down a bit and then they should work again (or untill it happens next time )
but i also recomend getting a new motor
MT
RE: Rustler Help
LOL you act like I know what the brushes are..lol No but I looked at the back and they both look the same ( if those copper things angles a bit are what the brushes are). Both look to be angled the same so not sure if I did it right or not.. Called my LHS and they have a upgrade motor that he said will be fast for $50 but didn't catch the name of it..lol Looking for a cheap good motor that will last and if I need to pay 50 or more then I want a really good one..lol
MT
RE: Rustler Help
ORIGINAL: Chris_RC
What about this motor?
http://www3.towerhobbies.com/cgi-bin...?&I=LXLRE3&P=7
CA
RE: Rustler Help
ORIGINAL: MTboy
shaunmichaeljohnson- Traxxas threads are the only ones you can find now. lol
CA
RE: Rustler Help
You can only run motors higher than 15 turns with the xl5 esc. More turns= more accelration, longer run time, less turns= higher top speed, less runtime, more maintence
Money motor, [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRBE9&P=ML[/link]
If you dont know how to solder get these, [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTJ21&P=M]Trinity no solder leads[/link]
and brushes, [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRBL8&P=M[/link]
Those are the only motors that will work with those brushes but they are very good and last a long time. Or you can go brushless and get a Sidewinder 5700.
MT
RE: Rustler Help
Man am I looking like a newbie..lol I'm really not new to the hobby just electric.. Run gas but now with my son running the Rustler and both of us working on a drifter I need to learn this so......
Ok I think if I knew how to take motor apart it could be the brushes..lol But I can't seem to get a hold on the back good enough to bend the tabs up so I can pull the back of the motor.. Is there a methid to this or a write up on it? Would like something to look at so I know that I'm doing right.. Really have to give you guys props for all the help.. Thanks for your help..
CA
RE: Rustler Help
ORIGINAL: MTboy
MT
RE: Rustler Help
LOL. that makes me feel better.. Thought it was just me.
Would like to go brushless but don't think the wife is going to go for that...
Thanks for the links. I'm thinking that those will work. Sound the money motor last longer? How often will I have to rebuild it?
What sucks is I know a couple runs on this motor I will burn out the esc and then have to get that..lol Just need to work on the wife and get brushless..lol
WA
RE: Rustler Help
i had a small rock get jammes inbetween the comm and brushes on a titan 12t on my stampede. does the motor shaft turn/ try blowing out the inside with and air compressor /electric cleaner.
CA
RE: Rustler Help
ORIGINAL: MTboy
