View Poll Results: A poll
Voters: 10. You may not vote on this poll
E-Maxx and tire ?????
Moderator
RE: E-Maxx and tire ?????
Razors for sure.
Yes with a 4x4 you'll loose some of the advantages of front wheel power, but with paddles you won't get much cornering performance.
If you're going to use the razors, might as well save your money and just run the dish wheels...
Since the E-Maxx is 4wd I'd go w/ paddles, just because they give you more forward bite...
idk about the motors getting bogged down though...
ORIGINAL: sheograth
You may get forward bite but you'll have pathetic cornering ability.
not anymore pathetic than the stock tires
check out some vids on youtube then make your decision...
i also say razors.
but here's the thing, ive seen a lot of vids and run 4wd and 2wd in sand, surprizingly the 2wd come out on top[X(]
but yes i think razors too as paddles are gonna throw sand straight into the body.
youre also gonna want heatsinks on the motors and keep an eye on the batt temps (assuming their nimh's) sand is really high load untill you get going.
when it gets moving the sand starts to seem like water does when barefooting and the load on the motors reduces a bit.
good luck
good luck
CA
ORIGINAL: rcdudegermy10
