slash isnt water proof when u go brushless??
WA
ok so i just happend across an article on here about the slash and someone said that once u go brushless its not water proof anymore, my question is then why does it state its waterproof, do you have continue to use brushed motors to keep it water proof?? i am confused now.
RE: slash isnt water proof when u go brushless??
ORIGINAL: hondaidiot
WA
hmmm ok interesting, learning something new everyday, glad i ran across that and asked, so this might be a dumb question but why cant they make a waterproof brushless motor i'm new to the rc stuff so just asking
Actually, brushless motors are more waterproof than a brushed motor, since in a properly made brushless motor, there will be no breaks in the insulation of the windings, so no place for the water to contact electricity in the motor...
Its actualy the brushless ESC's that are the problem... most arent waterproof.... If you get a waterproof brushless ESC your slash is still waterproof, but if not, then its not... all the stock parts are still waterproof, but the aftermarket non-waterproof ESC will be toast....
WA
well thats still good to know, i dont blame him for trying to help answer my question, but if i wasnt aware of that before i bought and some other newbie like me does that their probably gonna wounder why it died in the rain, i was just trying to find something that i could screw around with and praticing driving around not leave the car in pieces if i screwed up and smashed it into something so i figured i better find something pretty durable cause i have a tendacy to find things i'm not supposed to find and break it. i dont really care about speed to much and the only reason i asked about brushless is cause i heard the brushless motors last alot longer than the brushed one's so of course i'm gonna want something that lasts longer, but this is just gonna be a basher for me for now maybe if i like driving and get better at it i'll look into something else
anyways, just enjoy the waterproof feature as long as you can. and remember to spray all the screws and stuff that could rust with WD-40.
WA
good idea, thank god i almost own stock in wd-40 i've almost always got a can of it around somewhere. and yea ur most likely right about that new thread lol, will probably wind up posting one for advise but since i havent figured out how to get my money tree to grow yet[&o] it appears to be more than a month down the road
AB, CANADA
Just do what I do, use brushless when it's not wet and switch to brushed when it is... it only takes 5 min to make the change over.
ORIGINAL: AutoXMan
Dacaur you have it completely reversed, its the motors, not the esc's that are generally the problem.
AZ
ORIGINAL: AutoXMan
Most RC boaters dread splash-overs because it kills the electronics inside. They're sealed well enough, but usually not 100%. And a plane probably isn't going to get enough water in it to matter, unless it rolls on the landing, then they may have a problem.
Bottom line here is that all of the stock components on the slash are water RESISTANT. They kinda stretch the line there on the waterproof thing. You can drive it in puddles and splash around, but even Traxxas says you're not supposed to completely submerge it, which means its not actually waterPROOF.
Unless you get a BL ESC that says it is "waterproof", you're going to fry it the second you hit water. You can try to make it waterproof yourself, but that would void the warranty. As far as BL motors being "waterproof", the windings are supposed to be coated so they don't corrode, which would protect them from shorting if they get wet, but personally I wouldn't tempt it. Just get a cheap brushed motor (like the titan) and splash away with the stock ESC. That way if it toasts, you aren't out $80+ for a motor. Or $250 for a motor & ESC.
My Feedback: (34)
I have always heard that the stronger magnets in brushless motors are ruined by moisture. I rescently read of getting brushless outrunners wet without any problems several flights later so I'm not sure what to believe anymore. On the esc side, just buy a waterproof esc.
ORIGINAL: FairTax4me
As for moisture ruining a magnet, thats pure fiction. The Neodymium magnets used in brushless motors are always plated (normaly with nickel), so the moisture never even reaches the actual magnet....
My Feedback: (33)
ORIGINAL: Stampede Killer
then what about bl boats? and bl planes that land on water?
ORIGINAL: AutoXMan
Boats have a radio box where all the electronics are and sealed by the lid . Sure wouldn`t hold water out if the boat somehow sunk but good enough when running even with occasional dips under the water .
My Feedback: (34)
If the windings in a brushless motor are water tight, as are the magnets, then why the hell has everyone always said they are damaged by water? Maybe someone should step up and actually run an old one is water and see how it does. As I said, I have heard of brushless outrunners being completely wet without problems, so is all the hype possibly fictional? I'm pretty new to brushless, only owned one system so far and have run it on wet surfaces but have not actually submerged it or run in rain.
ORIGINAL: CustomTamiyas4Life
My Feedback: (34)
I'm not directing it to you. Look at most of the previous posts,most said the motors are not waterproof, and I have been hearing just that for years, but from what you are saying, I don't see why the motors wouldn't be waterproof.
ME
I ran brushless boats (and flipped them most of the time)and the motor was the least of your worries to get wet.Blow it out and spray the bearings after gettting wet with corosion X, wd-40 or some kinda lube and your good to go. The motor I used had air vents in the front and rear of the casing so it wasn't "sealed" up or nothing.
http://www.youtube.com/watch?v=URH_QC25YqM
I think this is stupid, i know that most brushless motors are "water proof" but most esc. are not i have learned this the hard way from float planes and bad placement of speed controls but the easiest way of finding out if the motor is water proof or not is to see if it says it is!!!. I have a stock slash and it's raining were i live but it has'nt held me back from submerging it in 2ft. deep puddles and it's fun. The only reason they state that it's water resistant not water proof is because they dont want to have to deal with people returning a product if something does happen to go wrong, say if a seal was'nt put on correctly, but for the most part they are watter proof.
hi
imo the "waterproof" feature in those trx models is far overrated. the idea of those nice blue servos, sealed receiver boxes, esc etc was not that you submerge you car but that you can drive in wet conditions. but of course some people tried to overdo it as could have been expected.
i would also say that the motor is not that much of a problem if its not one with a very open can. however i would run it completly under water on purpose.
there are several esc that are "waterproof". [link=http://www.mtroniks.net/]mtroniks[/link] for instance makes a waterproof esc too. also for bigger applications there are the kontronik jive that is waterproof.
just btw also a brushed motor "suffers" from being used in very wet conditions. especially if its dirty water which is usually the case.
bye
rhylsadar
bye
rhylsadar
