View Poll Results: A poll
Voters: 128. You may not vote on this poll
Traxxas Stampede or Losi High Roller??
RE: Traxxas Stampede or Losi High Roller??
pede has been around longer so many more hop ups.
the high roller was a bad move by losi, losi make great cars but this was a bad idea, pretty much coppying the pede.
shaun
shaun
AZ
ORIGINAL: Damo_MadTruck
Thanks, are there any other monster trucks like the stampede??
NJ
i have to gto wit the high roller cause it looks a bit wider so it would have more stability. it also has really nice tires wrapped around it. the shocks on it are alminum and the losi motor will prolly last longer then the titan
VT
totally pede, yeah so what if you burn the motor in 10 runs, just buy a venom fireball for like $20 they're cheep and good motors i like mine, preforms very nicely and lasts a long time i've never changed the brushes in 2 years, and it still runs strong
the lug
the lug
CA
ORIGINAL: rclugnut10
the lug
the lug
Venom motors suck. There is a 1/4 chance of getting a good one and people just buy in bulk because it isnt even worth it to change brushes.
ON, CANADA
Never seen anything good come out of venom. my buddy had a 5000mah lipo with a balancer and sure for 20 runs it was wicked, but then it swelled for some reason, and wouldnt last any longer then a 3300 nimh. also there motors are pretty shotty i had a 15t fireball back in the day also this highroller is a losi pede rip off, it wont be as durable im telling you right now traxxas trucks and cars are tanks, a wide pede is 14.75 inches wide the high roller is 12.75 a stock pede is one inch wider
CA
I have seen the high roller in real life, they just got a shipment in at the lhs. I would rather have my pede vxl. The motor is mounted on top of the transmission, the tires are kinda narrow, but are nice. but the shocks are weird, the ones on the pede are smoother. it uses a cheap motor and esc too. it just feels more fragile then a stampede. I would take the stampede, much more upgrades too since its been around longer.
CA
ORIGINAL: deanR
ORIGINAL: sheograth
I'd get the pede as well. The Losi 2wd off road transmission STILL has trouble with high power motors.
WA
HAVE YOU GUYS SEEN A HIGH ROLLER!?!
Just wanna let you know, it's a solid truck. Can't bash on it until you've driven, or at least seen one!!!
CA
ORIGINAL: Chris_RC
I have also seen them perform. Putting the motor at the top will make it a wheelie machine. So you are saying that Traxxas plastic shocks are better than Losi aluminum threaded body shocks? I have felt the shocks and IMO the Highroller shocks were smoother. And the Titan 12T isnt a cheap motor 9you can get a motor like the Titan for $5) and the XL-5 only handles 540 mtoors down to 15 turns, the Losi handles motors up to 12 turns. The HIGHroller is actually very strong. There was some big jumps people were taking it off and it didnt break and no problems.
The gear diff on the highroller is pretty durable. Losi's gear diff as seen on the DT and 1/10 Slider have held up to Sidewinder 4600/3s lipo. I dont know why you are saying STILL is having problems as the DT has only been out a couple months.
ORIGINAL: deanR
ORIGINAL: sheograth
I just bought a High Roller last week. The day after I bought it, I decided to add a mm 5700 kv combo along with a 3s 4000 mah lipo. Needless to say, I have been through 3 sets of transmission gears already. I am beginning to loathe my decision to step away from the pack by not running Traxxas. Anyone want to buy a barely used High Roller with aluminum arms? What I need to know now is what to put my ESC, 5700kv motor, and 3s lipo in that will at least last a full charge? PLEASE HELP!!!![:@]
I guess I wasn't clear on my pertinent question. What would be a good basher for my MM/5700kv cm36 on 3s 4000mah combo. I will be swtiching the High Roller back to brushed motor along with 3300 nimh 6 cell packs soon enough.
Yes, that is absolutely correct! Now, If I could just find the right bashing platform for my BL/Lipo combo. I wanna go fast!! PLEASE HELP!!!
ON, CANADA
stampede, you have people on here that dont no. they'll tell you a high roller then when your stuck with a truck that has no good hop ups breaks all the time and cant handle brushless, they laugh cause they told you to get it. the LHS will sell you anything, stick with what you no is good stampede steel idler steel ring gear on the diff or a whole steel diff, will handle anything 5HP brushless, hittin jumps with a locked slipper. plastic gears cant and will not take that kinda power, doesnt matter who says it
i wish i would've visited this forum before i spent nearly $300 on alum arms, hubs, spindles, etc... who wants a truck that cannot handle moderate power? not me
FL
ORIGINAL: Redvanmafia
CA
Redvanmafic, so your pretty much saying that that have drove the HIGHroller already because of your strong comments? How was it?
DarkShadow, I have never tested a Losi gear diff with 5700/3s power and there is no need to. My stock motor is fine for me. [8D] BUT if you build a ball diff right you wont have any problems. key word: IF YOU BUILD IT RIGHT!!!!
I already posted this on that other thread about the highroller, and if built properly plastic gears will handle lower turn brushed/brushless power.
As an example: [link]http://www.youtube.com/watch?v=8a-bz8RJ4aA[/link]
Losi has been using that transmission for 8 years with it only being revised (with the failure of the gen 2 tranny). Also if you build the Steal transmission it will be fine.
Chris, your information/assumptions are incorrect. As stated before, I HAVE a High Roller and I have 3 sets of trans gears to prove that it will NOT hold up to 5700kv/3s power! As for your implication that I have not built the trans correctly? I am sure I have done it correctly. Not exactly sure how else to build it. Now for the slipper comment-who wants to run their rig with the clutch so loose that the truck will not go through tall grass. I would love to know more about the steal(steel) trans you spoke of, though.
THEWHITEMULE
THEWHITEMULE
