3-cell lipo help
NY
3-cell lipo help
Is there an easy way to convert a 3-cell lipo to 2-cell. I bought a venom 3-cell 5400 mah lipo, and it is way out of control. IMO, there is no need for this much power. Would love to convert to 2-cell if its possible.
My Feedback: (325)
RE: 3-cell lipo help
Using the high voltage and a lower gear or lower kv is usually going to be a better set-up (having more runtime as well) if the weight isn't too much of an issue.
NY
ChrisRC, good idea, I am gonna do some research on that.
Longhair, everyone thats into rc knows you can go slower with less throttle. Please just answer the question without a smart remark, it is not needed in my world.
I dont even think, in my situation, a lower kv motor would do. I believe it would still be too much. I can never go full throttle with it, and i have raced successfully for 15 plus years, i know how to drive controllably.
Does anyone have experience with soldering a lipo, I have soldered batteries, motors, speedos, and recievers, and consider myself pretty good at it. But i am a little nervous about this one.
Thanks to all that has had an serious reply
speaking race wise, what kinda speed control are you running? castle creations has a software program thatll allow you set your own throttle curves, you could use that to lower your top speed as well as the responsiveness of your throttle.
but bashing wise, id go with longhair, at least youve got it when you want it, thats what i do as im not a racer and have busted the adapter off of my esc.
ORIGINAL: ftt4maniac
Take your problem for example - "it is way out of control".
You could adjust the Throttle Curve on the radio so you can get more or less than 50% at half throttle for example.
Forget everything you think you know and study the manual. You learn a lot and save money in the process.
NY
Sorry longhair, I guess i did judge your post wrong.
I could adjust the throttle curve, but i would really just like to convert to 2-cell.
Maybe i will post in the marketplace and swap for a 2-cell
Thanks again for the replies everyone
what you got man ive got a thunder power 2s 3900 graphite hardcase 30c 117a cont./ 234a burst, that i bought the day before yesterday i think, and want to go back to 3s as i smoked mine a few days ago. i had a 2600 and wasnt enough for my setup.
