Homemade project
Homemade project
hey,
I`m hoping to turn my cen into an eletric. any ideas on what motor and esc would be good? p.s this is a home project woth my dad soo i`m hoping to keep the cost down!
thanks dar.
thanks dar.
RE: Homemade project
i was thinking that these might work. any comments?
http://www3.towerhobbies.com/cgi-bin...1&P=0&I=LXUTA7
ME
If thats a 1/10th scale CEN(don't really know nitro cars well enough to identify) That system would work but I think the 5700kv or even the 4600 kv motor would be a better choice since the vehicle is probably on the heavier side being beefy for nitro. If its 1/8 scale you need a lower KV motor like something in 2000-3000 range.
If its 1/10th scale you can use 2s lipo(7.4volts) or 3s lipo(11.1volts). If its 1/8th scale you'll need atleast 4s lipo(14.8 volts) or 5s lipo(18.5volts)
yea, your right it is a 1/10th scale. i was thinking the 7700kv because i was afraid that the lower kv motors might have too much torque and would strip diffs and gears![:'(]
as for battery packs i was thinking off something like an 8 cell nimh. Would it be worth using a lipo??
VT
ORIGINAL: dar123
the lug
i think i`ll stick to a good nimh pack. i`m still trying to figure out how to make the brakes work!? can i make the transmission lock both ways? or do i have to get a 3-channel radio? and use the existing throttle servo for the barkes?
CA
disable the reverse on the ESC and use a "Y" connector between the servo and the ESC, when you accelerate the servo moves out like in a normal nitro operation, when you hit the brakes, the ESC doesn't have any brakes (disabled), so the mechanical brakes take over, little fancy but it should give the results you want[8D]
thanks! sounds like it`ll work. ok, i`ve got a bit of a problem. i can`t find any mamba systems in the uk. they`re all in the U.S! anybody no of a good system taht i can but in Ireland or the U.k? here is a few more pictures off it all clean and ready for the eletricts![>:]
hmm... i can`t upload the pics for some reason![:@]
thanks raymanh, would the LRP Brushless A.I. and Eraser 9.5T Combo be good? what do you think to this charger aswell? http://www.modelsport.co.uk/?CallFun...n&ItemID=28791
