ESC Shielding.
ESC Shielding.
I have a stampede vxl, and at times I drive without the body. I was wondering how I could protect the esc when I don't drive without the body, any ideas?
My supplies are a dremel, a sheet of steel, some screws and nuts, and your everyday house tools.
Any ideas are appreciated. I was thinking about something that bolted to the holes where the rear body posts would be, or something that in some way wrapped around the chassis..
Thanks!
Thanks!
CA
RE: So, how's this going to work out?
If possible, cut the steel to the length of the body mounts (like a long rectangle). Drill some holes so you can mount the steel useing some body clips. Might work....[&o] (If your flip over you'll have a sweet "sparks" show... right in your own front yard )
You could just put the body on...
I would avoid using any object that will promote radio inference. (such as sheet metal)
RCcars4me - That sounds plausible, but the only problem is that the body mounts are so weak and bendable that I don't even trust them to support the truck when I lay it upside-down to do work on the underside. Thanks for the idea, though!
FairTax4Me - Yes, but I've gone through so many bodies that I could have spent the money on something nice, like an flm super chassis. I was also thinking about just taking a break with using bodies for a little bit. (But you can rest assured, if I try something crazy like a frontflip, I will be sure to use a body! lol)
