problems with slash with velineon brushless
SC
I have a slash that has the velineon brushless conversion. I cant get the motor to quit cogging. Can a brushless motor go bad? It had the 22 tooth pinion with a 90tooth spur. I tried putting a 17tooth pinion on it but that only helped a little. I pretty much have to push the truck to get it going. It does this with my venom 4200 6 cell pack which is a known good pack. I have a 3 cell lipo that I tried on it which it still cogged for a second or two at 11.1 volts. I had a rustler vxl and never had these problems. Any suggestions?
RE: problems with slash with velineon brushless
ORIGINAL: cornel4web
cogging is normal for brushless sensorless...so, just hit hard the gas...
Cogging occurs when you are using the incorrect gearing and is not a normal thing that happens with sensorless setups.
Try dropping down to a 16t or 15t pinion and you shouldn't have any more cogging problems.
SC
I just charged up a new 7 cell venom 4200 pack and went to the 17tooth pinion and it works alot better now, not nearly as fast as the rusler vxl I had though.
ORIGINAL: buscg1
My Feedback: (35)
ORIGINAL: buscg1
MO
ORIGINAL: zsultan
I have noticed the same with stock pinion and vxl, its performance is not very impressive. I liked the rustler vxl much better than slash vxl for performance and slash for scale look. So i bought a rustler vxl and slash stock yesterday, planning on keeping the slash stock.
ORIGINAL: buscg1
ORIGINAL: Ttam Says Blarg
My guess is because your trying to use venom on a brushless system.. Venoms are not proven batteries. LOL
I run Venom 3300's on a Mamba Max 5700 and Mamba Max 4600 setups in my kids' Pedes without any problems.
I have the slash with Velineon running 23/86 gearing and never ever had the slighest problme with cogging. I use 2s batteries and it runs beautifully. As t9dragon said play with the geering more.
Uh, I run 29/76 gearing in mine, and don't have any more cogging than I would expect.
90% sure it's the batteries or motor itself. Or it's just you being a worry wart, as has been mentioned all sensorless motors will cog a bit.
About 20mph on the top end It's speed run gearing, if you try to run the truck as a basher with that gearing you will fry something. However, I still don't have a problem with cogging so that points to it being something else on his truck.
MI
I have that system too but when ever i turn mine on everything works well but the throttle. In fact i have no throttle. my esc just sits there staying green. I am running lipo and i do have it on lipo cut off. Does anyone know what is wrong?
