...::Oday's E-REVO 3.3 Build::...
#153
My Feedback: (8)
RE: ...::Oday's PICCO powered REVO Build::...
I just ordered a MMM from BPP with a cupon for $143 shipped! I also ordered an RCM pionion and some deans. I will be running early to mid this week!
#154
MO
ORIGINAL: Krawlin
Just a word of advice, I would put some more padding on that tray and put ends on it, just bolting on some lexan or aluminum ends would be good. Because if you jump it and land hard on the front or rear the battery will slide off. Better to be safe than sorry, so just put end caps on both ends of it, maybe even redo the tray with C channel aluminum so you have 2 sides on it then bolt ends on it as well.
#156
Even if you have several straps it wont hold. And remember that the velcro straps can slide and move, so like Fuse said, don't rely on them to hold anything, however I wouldn't rely on them even with 3 or 4 of them. Just make a new tray with C channel aluminum and bolt some ends onto it.
#158
MO
Just make a whole new one with 4 sides and a bottom. Then cut some slots in the top and use some velcro straps, heavy duty ones. I use some align ones from my hobby shop and they work great.
#160
My Feedback: (8)
great! but it eats spurs alive no matter what I do![&o] Im gonna get a steel one soon. or do an emaxx trans and get a steel emaxx spur. still undecided
#161
An E-maxx tranny would work good except for the fact that because you have that big 5S pack on 1 side, you need the motor on the other to help balance it out a bit, plus the E-Maxx tranny would put the motor up pretty high. Put the motor any closer to the right and your handling will suffer, same goes for raising it up.
#162
My Feedback: (34)
Eating spurs? Is your mesh way off? My pinion is only touching about half of the spur because the shaft on the motor I'm using is too short, but I have yet to strip one spur. And that is on 4s and it has enough torque to pull wheelies at any speed.
#163
My Feedback: (8)
Mine is pulling wheelies at any speed and has tons of torque. the mesh is good. idk. maybe i had bad spurs...any case im getting a steel one soon
