duratrax evader ext
MI
duratrax evader ext
Im thinkin on buying a evader ext, Is it a good truck? who has the lowest prices? and what are some alternatives? Is there a big line of aftermarket parts for it?
thanks
thanks
OR
RE: duratrax evader ext
It is a great driving truck. The parts on the evader vehicles are a bit fragile, but the truck has a great advantage over the evader buggy, the body covers alot of the fragile parts on the truck. The rear bulkhead is kinda fragile but easily modded to be stronger, or an aluminum replacement is available I believe, but that defeats the purpous of buying a low budget truck IMO since the aluminum parts for the Evader vehicles are ridiculously expensive. It would be my recommendation to step up to the next level up Evader truck at $150 though. You get full ball bearings, better shocks, a faster motor and a better ESC. Very well worth the extra $30! I would avoid the buggy alltogether, the shock towers are like peanut brittle on these cars, but the truck has them protected by the body so it is a non-issue.
OH
The EXT is made with "Magnaflex" plastic which is much more flexible than the plastic used on the ST. It should hold up to abuse much better. The downside is it won't hold the suspension geometry as well for racing (who competitvely races EXT's though???). I say go for it for a backyard basher, if you like it, find a bearing set as your first upgrade then maybe a cheap brushless system when you get the need for speed. Castle Sidewinder is great and I've read some good things about EZ-Run.
OR
ORIGINAL: ethanwillson
budget monty, are you talking about the evader st???
MI
so the plastic on the ext is better than the st? Or the other way around? Im really not too worried about the plastic breaking because I probally just replace them with aluminum parts if there are any available for it. i plan on just using it for bashing in the backyard.
OH
MI
there goin for $90 on ebay. I just checked, Im lookin for somethin bigger to play with other than my mini-t, somethin my brothers t-maxx can't run over too easily lol.
if you don't want to get run over by a t-maxx, a low to the ground stadium truck isnt the way to go, maby a stampede or something like that would be better.... That is, I'm assuming he literally runs over the top of your truck....
CA
I had the EXT and it was a great truck. Very tough truck but the stock motor is pathetic. It WILL go out on you and the stock ESC cant handle a higher turn motor. The stock motor is, I think, 20 turn. I put a 27 turn and the ESC would overheat in 5 minutes.
If your looking to upgrade the motor and ESC, then get it. For the price, its a tough truck and you can bash it pretty hard.
ON, CANADA
ORIGINAL: Budget Monty
Actually, I was using that as my reference, but as the last poster stated, I may have been misinformed that the EXT uses the same plastic as the ST. That would make for a much better truck! I sold my Evader Buggy (BX) because I could just no longer deal with how fragile the shock towers were, I was afraid to drive it. I would order shock towers 3 at a time front and rear! I have had many buggies, and this is the only one that I had this issue with. My buddy has a BX still and will be glad to hear that the EXT/EXB uses better shock towers!
MI
well i really like the stadium trucks, and yes he literally runs my mini-t over with his stampede and t-maxx. I just want something bigger and faster with a brushless motor to outrun him, I could make the mini-t faster but i can get a new duratrax for the price of a brushless motor for the mini-t. The more trucks I have the better, lol.
OR
or get a rustler VXL for $250, brushless out the gate, comes with bearings and an all metal tranny.... how long do you think an evaders plastic gears will last on brushless power? If you want a brushless vehicle that can actually handle brushless power at the lowest possible cost, the traxxas VXL's are the way to go....
OH
ORIGINAL: dacaur
Not a bad suggestion, I would consider it.
ON, CANADA
ORIGINAL: dacaur
OR
My buddy just got his MM/5700 system in his evader BX tonight. It was too fast to run tonight (It had rained hours earlier, and the ground was still a tad wet). We could not keep it from looping out. And I dont just mean "It was really fast", we literally stopped driving it because it was unmanagable on a 6C 3600 NiMh. Hope to get a dry run in soon! I guess we will see how the car holds up!
hey ive had an evader for about 6 months i got a trinity colbalt 27 turn motor put it on and no my esc is acting funny. like won't go in reverse and it has a very short range compared to what it used to be????? anyone have any ideas
my evader st was my first real rc truck and i luv it. its very durable it takes more abuse then emaxx ever did. i did break the rear shock tower wheich i replaced with a metal one and i striped the servo gears other then that i havnt touched a thing. my i suggest the slash? i got my slash this summer and ive hit curbs, light poles, other cars etc and this thing is a tank! i dunno what traxxas made it out of but wow its strong also the slashs tranny is brushless ready unlike the evader. why not upgrade to the evader st?
