A maths question 4 all to help with!
Can anyone help we work out the charge time 4 my new batt?
The charger outs out 7.2v at 800mA
and the batt is a brand new 3800mAh Ni-mh batt made by enrichpower
can some one please help (down on knees begging) lol
p.s the charger has no cut off to stop when the batt is fully charged.
Moderator
RE: A maths question 4 all to help with!
You'll need a higher output voltage to charge a 7.2v battery - you can't just apply 7.2v to it. I'd invest in a real charger before you damage your batteries.
1 Post
ORIGINAL: sheograth
The cheap walwarts that come with some rtr's are 7.2 volt.
1 Post
ORIGINAL: d.k.v
i cant wait that long lol
iv only been charging it 4 an hour and a 40 min ops
Moderator
The cells need to be charged at a higher voltage than their rating for them to take any significant juice. If you take a drained or semi drained 7.2v battery and apply 7.2v - you won't get much performance no matter how long you leave it on there.
1 Post
ORIGINAL: sheograth
Moderator
It's probably called that because it's for 7.2 volt batteries, if you checked it's output with a meter it's likely higher.
yer i might get my dad to do it with his new meter ( i blew the last one up ... luckly supplyed by his work)
i put it onto a 9v batt to work out its amps and the meter went pooff
it was a expensive one too...
it was on the fused conections but it was kinda old and wat i didnt no was b4 my dad got it they put a fuse rated at 5 x whats ment to be in it
