lipo charge/balancing
ON, CANADA
hey,
I have a 4s 5000mah lipo. what charge current should I use? is it better to use lower charge currents for the battery?advantages/disadvantages?
sorry, 1st lipo, im a electric newb []
RE: lipo charge/balancing
With a 5000mah battery you should charge it at about 5 amps or a little less. It is better to charge it slow verses charging it fast. It will last longer over the long run if charged at or below 5 amps. Make sure you use a balancer to keep the cells balanced.
If you have any other questions feel free to ask.
Josh,
Josh,
Like Pulse said. You can charge up to 5 amp but all batteries will last longer if charged slower. I personally never charge over 2.5A on any of my batteries. I have two chargers and Lipos run so long that charging really isn't a problem for me.
Also you can never balance too much. I balance my packs before they go on the charger, during charging and I leave it on for a few minutes after I'm done charging. I also balance right after the pack comes out of the car. Just don't forget and leave the balancer hooked up. It will eventually kill the battery
You take the mah of the battery and divide it by 1000 to get the C rating.
Ex. 2500mah divided by 1000 = 2.5
So you would charge it at 2.5 amps.
Josh,
Josh,
When storing li-po batteries I like to keep them at about 3.6-3.7 volts per cell. This will slow down the deteriation rate of the battery but is not too low that it damages it. So with a 4-cell li-po it would be about 14.4 to 14.8 volts.
Josh,
Josh,
ON, CANADA
one more question josh, can you run a voltage monitor on your lipo, while running the lipo itsself?will it cause any damage?
ORIGINAL: PulseXT40
What I do is, when charging a fully discharged cell, I set the charger (intellipeak ICE) to stop after 40% charge. Then I store it, and before running I take them out and charge them the rest of the way.
