Thunder Tiger Sparrowhawk XT
#226
RE: Thunder Tiger Sparrowhawk XT
nope, they are HPI v-grooves (http://www.hpiracing.com/products/en/4450/) but yes they mounted right on.
#227
Hey Guys
This XT model come with sway bar ?
I bought this tires to run on street:
http://www3.omnimodels.com/cgi-bin/w...I=PROC1062&P=7
When arrived I'll post some pictures...
#229
<xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w:HyphenationZone>21</w:HyphenationZone><w:PunctuationKerning /><w:ValidateAgainstSchemas /><w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid><w:IgnoreMixedContent>false</w:IgnoreMixedContent><w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText><w:Compatibility><w:BreakWrappedTables /><w:SnapToGridInCell /><w:WrapTextWithPunct /><w:UseAsianBreakRules /><wontGrowAutofit /></w:Compatibility><w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel></w:WordDocument></xml><xml><w:LatentStyles DefLockedState="false" LatentStyleCount="156"></w:LatentStyles></xml><style> Style Definitions */table.MsoNormalTable{mso-style-name:"Table Normal";mso-tstyle-rowband-size:0;mso-tstyle-colband-size:0;mso-style-noshow:yes;mso-style-parent:"";mso-padding-alt:0cm 5.4pt 0cm 5.4pt;mso-para-margin:0cm;mso-para-margin-bottom:.0001pt;mso-pagination:widow-orphan;font-size:10.0pt;font-family:"Times New Roman";mso-ansi-language:#0400;mso-fareast-language:#0400;mso-bidi-language:#0400;}</style>
Hi guys,
I have one EZRUN COMBO 8.5T 4000kv. Anybody know if this kit is good for SparrowHawk XT ?
#233
G'day
I have not used my XXT for a few months now as I keep poping out the cetre drive shaft [:@], I have tried loctight etc but still no luck. Any other suggestions which may help????
Cheers
Cheers
#234
Well I learned the hard way. All it took was 2 battery packs before those dreaded grub screws came loose. The LocTite was a Godsend to me though unlike you. Look closely and you can adjust the play (by moving it n forth ) and "fine tune it") on the shaft because I was able to find that sweet spot with virtually no play. Make sure you let that Loctite dry too.
Very fun truck...don't give up on it
#235
motor swop
Hi guys, so my 550 type 19 turn motor of my XT blew, or is jammed, I'm not sure. But i want to swop it out with a new motor. However i can only find a 12 turn or 21 turn motor. Will my XT be able to handle these different motors or will it do damage to my car? Are there any preferable brands that are trustworthy and quailty? I got VGEBY, INJORA, Dilvwe, and crazepony.
thanks
thanks
