Traxxas VXL Owners, Which Lipos and Charger/Balancer Are You Using?
NY
RE: Traxxas VXL Owners, Which Lipos and Charger/Balancer Are You Using?
hey there VGE,
i have only been using nitro in the past. i recently started a nitro - electric conversion on one of my super nitro rally, and i picked up the Traxxas VXL brushless system. i have been eyeing that venom charger from tower hobbies and trying to decide which lipo pack to use. i have no experience with the electric side of rc, so im on a major learning curve here. so maybe you can give me a few pointers? after reading your post on the venom charger, im definitely gonna pick one up. can you point me in the right direction for the lipo packs? this is not for racing, just for bashing. initially i was thinking of the venom 3s 5000mah...but those are like 150.00 or so...what do you suggest ? and if possible can you give me a link to it?
also you mentioned lipo bags, i guess that after reading a lot of warnings about lipos i was getting cold feet but again, after reading your post, i feel somewhat more confident. what exactly are these lipo bags? do you use them to charge as well as store the lipos? are they supposed to be fire proof?
PA
ORIGINAL: prestonlal
hey there VGE,
hey there VGE,
PA
ORIGINAL: Traxxas4fun
LOL how much are a123 and a charger?
NY
Sweet! hey thanks for the info...gonna look for the lipos tonite and pick up a few, as well as the lipo bag. will posts some pics later when i done with my conversion.
thanks again!
thanks again!
#31
FYI - LiPo bags are rip-offs.
Just put the LiPo in a glass baking dish and make sure it isn't next to something flammable. It worked for preventing a house fire with that LiPo fire I mentioned.
vge - I got one of those Shark 1500 NiCd packs "free" with my Lunch Box from ebay. The only thing I did was put a Deans on it and charge it up. All is well so far, it took 1300 mAh of charge. I'll keep an eye on it though.
I may try one of those Hong Kong LiPos too. Did you say they have PolyQuest/Hyperion balance taps? You're using them with your Velineon system and they work OK? Do you know how much current you're drawing from that brushless system? Because 15C 4 Ah LiPos are only good for 60 A. How warm are they after a hard run in the grass?
#32
A 1500 pack at 3A. I think I know why it popped. There is also a good chance the 15 min charger had an issue. I've had a couple of those go bad over the years. I do believe that Nimh is just as dangerous as Lipo. I've popped a pair of IB packs. One popped a cell in a tamiya re-re with a stock silver can. The other popped on the charger at 2.5A. It was a 4200mah battery. Funny thing is I've never had a Lipo do anything bad. I've had one die and early death but nothing happened. it just wouldn't take a charge. I've been around packs when they've been crushed, torn open, holes in them etc. The worst i've seen is smoke and a spark. he fear or Lipo's is seriously over hyped. After the Nimh pack popped I learned not to leave any of my batteries laying around unattended. Just store them in a safe place when not in use.
#34
ORIGINAL: john01374
Nitro - I've only had the Venom charger for about 2 weeks but i've charged about 30 packs on it so far. It's operated perfect and once you understand how it works it's pretty simple and gives you a lot of good info. YES the Balance plug on the Zippys plugs right into the balancer that comes with the Venom charger. No adapter required.
The balancer is built in to the Venom charger, correct? No messing around with a balancer seperate from the charger?
If you guys want to try LiPos that you don't have to worry about running too low, you should try Air Thunder. They are as expensive as the big brand name batts, but they can be run down pretty far without worrying.
#35
PA
ORIGINAL: Jeremy Z
Jeremy Z - They work great, I never had any problems out of them. They dont get any warmer than any other batteries I use. I usually run them and pull them so they can rest then move on to others. They work great with my Slash which has the VXL system in it.
I guess the lipo bag is to each his own. I like having it. I have seen a battery catch fire inside it and I liked how it handled the fire. I dont think I want to just toss it in a bowl for me an open flame is asking for it if something does happen. The lipo bag will put the flame out. For $20 - $30 bucks it just some extra insurance I guess.
NitroEddie - The balancer plugs into the side of the charger. I guess they made it that way so you dont have to use it. When I am doing NiMH batteries or anything else I dont have it plugged up. I kinda like it hanging off a little because those balancing leads are never very long.
#37
PA
man 20 bucks for two no name lipos that could be potentially dangerous... uhh dunno bout that one..
#39
PA
ORIGINAL: NitroEddie
vge, for some reason I can't get your video to work.
http://s131.photobucket.com/albums/p...t=100_1527.flv
#40
Got it, thanks. Looks like a good value for the money.
Does anyone else know what other LiPo brands use the same connector as the Venom charger? So far we got Zippy and I would assume Venom LiPos use the same connector.
#41
umm...by the way... how long does it take generally to charge a lipo..like that 4000mah 11.1v pack?
#42
By the way fellas, vge's burnt-up battery pack was a NiCd, not NiMH. It is perfectly OK to charge 1.5 Ah NiCds at 5 A. (If they're assembled properly and of decent quality) NiCds aren't as picky as NiMH, which is one of their virtues.
#43
WA
I use two 4000mah 2s1p 25c zippy flightmax hardcase batteries. And I love them! half the price of my 7 cell nimh and a lot more punch and half the weight and 30+ minutes of runtime with VXl in my stampede geared 19/86. I charge them at 3.5A (just under 1c) and they barely get warm. I think about 23C was the hottest it got, and after 30 minutes of straight hard running they were barely even warm. and the charger I use is a Thunder AC-6. Its cheap $75 shipped to my door with a lipo bag and has a lot of features like built in balancing, Nimh, nicd, liion, lipo, Life, lead acid, temperature sensor, AC/DC power, lots of differect connectors, USB/PC connection, charge/discharge/balace/cycle, it shows each individual cell voltage while balancing, up to 6s lipo forgot the lead acid and nimh/nicd, differect balance/peak detection settings, its small, has a really easy to read LCD, timer and charges .1A to 5A.
#44
MO
Price has nothing to do with quality. You can get Enerland labeled batteries from hobbycity. Enerland is one of the best cells out today, yet they are cheap at that site. Does that mean they are not as good?
#45
Couple questions while I have your attention...
Is it necessary to use the optional ESC fan while running 3S in grass? Also, what is the stock gearing on the VXL Stampede? The gear/speed chart says 25/86, but elsewhere on the Traxxas site it says the truck uses a 19T pinion stock.
#46
PA
#47
That's my line of thinking as well. I had a 'pede converted to brushless with a Novak 5800 system a few years ago and ran a Novak ESC fan on it.
Do you know for sure what the stock gearing is?
#50
NY
hey VGE,
do you have a recommendation for a motor heatsink for the velineon motor? i couldn't find one on towerhobbies site specifically for this motor, and the other brands of heat sinks on there site doesn't have enough info that tells me if they will fit. any assistance here is appreciated...
