Mamba 5700 / Max SC overheat
MT
RE: Mamba 5700 / Max SC overheat
ORIGINAL: FairTax4me
Try super gluing a hex wrench (use just a very small drop of glue) into the grub screw. Sometimes that works.
If I really want to try that pinion, I'll try the superglue method.
CA
ORIGINAL: Redvanmafia
if you got that many heatsinks, and you still overheat your doing sumthing really really wrong, i wish i had that heatsink set up so my motor could be Cold like -1 or 2 degrees lmao
Actually heat sinks work a lot better than 1 or 2 degrees
GA
Well after battling with getting the grub screw out of the 23T pinion I was finally able to put a 16T on with the 90T spur to try that combo. Still running way hot and getting thermal shutdown after about 3 min if running. I have a 12T pinion but it is wasn't meshing with the spur and later found out it was the wrong pitch. I moved the ESC to the side of the truck opposite the receiver as it was on top where the original ESC was. Was hoping that turning the ESC so that the fins running parallel to the length of the truck would help with the cooling. This last attempt was with the top off as has been most of my tests. I'm going to order a 12T that will work and try that.
My Feedback: (20)
NY
if your motor got over 200 degrees it is already prob worthless as once it gets that hot it starts to de - magnatize , also cut some holes in your body leading to the esc so air can get to it while your running . it may help , i have a mamba max and vxl motor on my slash currently running 22/86 gearing with no problems at all ... good luck
#31
IL
ORIGINAL: harrier
OK, so I got my gears in the mail today. Put the 90T spur on no problem. 23T pinion set screw is stripped. I've tried gripping it with pliers and using an extractor. How the heck do I get this stupid thing out?
#32
IL
ORIGINAL: JUSTPASSEDU
#33
IL
#34
GA
All this testing has been with no body on the chassis. It's all open. Now, is running electric vehicles like computers where you need the case on the computer for maximum air flow? I told some guys that worked for me in a datacenter that the cases needed to remain on the servers when there were in operation or they would overheat. They didn't believe me until one over heated when it was run hard with the case off. Put the case on and no issues. I know they are not related but just pulling at straws.
In the Slash setup... what Lipos are you using specifically? Mah, burst rate, cell count....?
#35
IL
ORIGINAL: harrier
#36
im just wondering. how do i get fans to work, i bought an integy fan for my motor, and i have a traxxas 2ch rx+ battery channel it has the bec, its the xl-5 old rx..
the plug for the fan wont run go i on the rx?
