slash- best combo
slash- best combo
im looking 4 a good combo 4 my slash. i was looking at a vxl. im only going to run a nimh batt or mabye twin nimh.
would this work?
would this work?
RE: slash- best combo
Depending on the size of the "twin" nimh packs you wont be able to run both. It can only handle 3S lipo or 9 cell nimh.
The VXL is a fine choice and bolts right into the slash chassis. There are better systems out there but the VXL is a very good system.
i was thinking of running twin 3800 or 4500 mah packs 6 cells. what else is there on the market 4 the same kind of money??
ORIGINAL: d.k.v
Mamba has a couple systems, losi has the Xcelorion, novak has several systems, etc. There are tons of them. Just look around some online stores like towerhobbies.com, amainhobbies.com, ultimatehobbies.com, stormerhobbies.com, hobbypeople.net
thanks. couldnt you put gome copasitor between the batterys and the esc to reduce it to 10. whatever (the max voltage)?
Any particular reason you want to run twin NIMH versus running a good 3 cell Lipo? A couple of NIMH will be really heavy. If you want to get max voltage from NIMH to run in a VXL, you could just buy a 10 cell battery or have one soldered up so it fits within the Slash batery tray.
