Battery gets hot, but ESC/Motor still stay cool
My Feedback: (32)
MN
While running my Losi DT I have noticed that my older NiCd batteries get pretty hot (much hotter than if I am running higher capacity NiMh batteries). The truck has stock gearing a 17t Speed Gems Motor and Novak Tempest Pro Esc. Are the batteries only getting hot because they are not able to supply the needed current to the motor/esc? I am also having the same problem on my E-maxx which has a Kershaw Designs single 970 conversion and Novak Super Duty ESC. When I run 3000mah NiMh batteries they are very hot at the end of the run. Do you think that going to a 20C lipo would make any difference? Any suggestions are appreciated. Thanks!
RE: Battery gets hot, but ESC/Motor still stay cool
I have used Ni-MH, NiCd and Lipo on my Slash. Lipo runs very cool, very little heat at the end of the run. However, Ni-MH, NiCd runs alot hotter than Lipos.
Even during charging, NI-MH, NiCd can get pretty hot too while Lipo stays super cool.
My Feedback: (325)
Yes, you're right on both accounts. The heat comes from the higher IR nicads compared to better nimh batts. This graph may illustrate the temp. At lower currents it wouldn't matter since neither battery will get hot. http://www.rcuniverse.com/forum/fb.asp?m=8875774 It's the graph on the right of post 30 and they are all the same cells.
My Feedback: (325)
Using a 20C lipo is only half of the story, the other half is the capacity since they get multiplied together to find current.
http://www.promatchracing.com/proddetail.php?prod=7460S
Free Priority Mail shipping if you spend $100. Worth every penny.
My Feedback: (32)
MN
Just wondering if running the cheap batteries will cause any damage to the motor/esc, or will it only shorten the life of the batteries due to the heat? I ask beause I have accumulted like 20 1500-2000mah Nicds which work fine with the vintage tamiyas ans such.
VT
they won't really hurt the motors but its like running 10% nitro in your $500 race engine you're just limiting the poor beast, i don't even run my nicads in anything but my roto now after seeing the power gains from my EP4200's and 4600's they are just that much more powerful, i saw 3-4 mph on a crappy motor with just a battery change, with a quality motor i'd expect to see somewhere arond 5mph or so
the lug
the lug
" While running my Losi DT I have noticed that my older NiCd batteries get pretty hot ".........................you mentioned older.......not good, and nicads..............not good. Go with lipos, you will eventually anyway, you will need an low voltage cutoff, tower sell a 4s for 25 bucks.
My Feedback: (32)
MN
You are probably right, I will probably just sell them off on eBay and get some lipos. Thanks for the advice
The hot batteries won't damage anything. If you do go for the LiPos, don't forget to re-gear it once you do. Most likely you should move it down a tooth or two.
