Sidewinder with Velineon Motor
MN
RE: Sidewinder with Velineon Motor
ORIGINAL: Traxxas4fun
try 19/80 gearing on 7 cell it should not reach over 160..
i can run like 18.86 with pede tires on highest setting for prolly 15 minutes straight around my track and it gets to 150ish after 15 min
MN
ORIGINAL: monsterbombs
the difference in the c rating usually is in
wich manufacturer is less embelishing the fugures.
some companys say 30c but there not. a 15c burst
batterie will struggle to give you all the punch.
compare that to a true 20/25c batterie it will
blow it out the water torque wise. anything
that has over 100amps of discharge and is true
20/25c is good.
20/25c is good.
