Slash vs rustler vs micro t vs mini t
RE: Slash vs rustler vs micro t vs mini t
are you wanting to know about the 1/16th scale slash or the 1/10 scale because the 10th scale is cheaper
http://www.amainhobbies.com/product_...attery-Charger
and if you decide on a mini-t i would get this one over the original
http://www.amainhobbies.com/product_...dium-Truck-RTR
the original isn't that great and that limited edition is the best one they made, it was once released as the mini-baja before vw got to them about using the bug shell without permission. they released it as the one in the link.
I have a traxxas slash and the Mini-baja i mentioned before. Love both and have had alot of fun with both.
i'm talking about the cheaper one wich is 2wd and xl5 if i am not mistakening. Do you have the xl5 or vlx? and will the xl5 last me a while.
MI
I have three of the four cars you listed (no Slash...yet) and all three are great cars in various settings. The Rustler is great if you run in rough terrain but it's also good on smooth lots. If you go brushless, you'll need a large area to really have fun. While the Micro T can be run outside, it really needs a smooth surface and is a better indoor car. The Mini-T seems to be a good compromise between the two, big enough to run outside, so long as it isn't too bumpy or soft (low ground clearance) but it really doesn't need a huge area to stretch out. With my brushed motor Mini-T's, I run them in the driveway and it works well, but I think they are a little large to run in a basement unless it's decent sized. I went brushless in a couple of my other Mini-T's and they are as quick as my brushless Rustlers on smooth surfaces like asphalt parking lots. But add a little soft dirt or decent size bumps and the Mini-T is out of the running with the Rustler. Lately I've been spending more time running the Mini-T's, again because they're able to run in smaller areas.
As far as replacement parts and durability, they pretty much are the same; parts are plentiful and fairly cheap. The biggest difference I've found is the cost of batteries and upgrades. You can get decent lipos for the Mini-T fairly cheap - about $7 - compared to $30 for the Rustler (both from HobbyCity.com). Uprgrades are also much cheaper for the Mini-T, whether you're referring to shocks, tires or motors. The Mini-T and Micro-T's require a few more upgrades than the Rustler to really enjoy, and the one of the downfalls for both is that they have a combined esc/tx, so to upgrade, you'll have to get separate escs and rx, plus with the Mini, you'll need a new servo since the stock one only works with the stock rx/esc. The good news is that you do that fairly cheaply.
While it may be a toss up between the Rustler and the Mini, the Micro IMO is really a "spare car" for specific conditions, mainly indoors.
alright, thanks alot guys. I think i'll go with the slash as i hear lots of good stuff about it. But if i change my ming i will let you's know.
does anyone have a micro t for sale??
i have the slash with the xl5 esc its great fun. parts are plentiful and should you choose to race it the tracks have a slash class to race it in. mine is being driven around the house etc.
