4WD electric buggy with good ground clearance
ive ben looking for a4WD electric buggy with good ground clearance if you have one in mind please tell me other wise ive ben looking at the cyber 10b kit and the brama 10b but what i dont get is the cyber 10b kit is more and it doesnt come with a motor transmitter or servo
My Feedback: (10)
RE: 4WD electric buggy with good ground clearance
I have heard decent stuff about the cyber but not so good about the brama. in the same price range is the thunder tiger sparrowhawk and I have read decent reviews of that one too. but I have no idea of clearance on any of them being buggies. on the other hand, being 4wd I would bet they can handle some terrain.
QC, CANADA
ORIGINAL: huntergalles
AB, CANADA
The design of buggies is such that they don't have high ground clearance. You need either a truggy, truck or monster truck. The advantage of a buggy is that it is more stable at higher speeds and tends to handle better.
I'd also suggest you look at the Tamiya buggies, they are kits so you have to build them which I find to be a lot of fun.
CA
If you must have a buggy, along with the Tamiyas, look at Kyoshos. The Kyosho ZX-5 is available as an RTR.
But as Druss mentioned, buggies and ground clearance are mutually exclusive. You can get some 1/10 truck wheels/tires for it to increase the ground clearance, but that's it. They have short suspension arms also that limit travel.
IL
ORIGINAL: Druss
The sand fire dune buggy looks really bad***, but I can imagine that it handles like a stampede, because it uses a stampede rear end.
edit: It's also only 2wd, but I believe it has plenty of ground clearance.
CT
i am not sure about the cyber 10b but i have the brama and i got to tell you its a bummer. its not fast at all on or off the track and needs upgrades. on the track if i dont land perfectly on a jump i will bottom out and when you hit this chassis you will either tumble or pop up off the ground
if its stock its a brushed system with would explain why its so slow put something like this in ithttp://www.castlecreations.com/products/mamba_max.htmlorhttp://www.castlecreations.com/products/sidewinder.htmlthe mamba max is more programable and can handle more cells than the sidewinder but the sidewinder is less expensive
yup and if your looking for something waterproof look at traxxas new waterproof vxl system its more torqie than other systems to
CT
thank you that will be something i will look at but, if i put a new motor and esc in my brama will i have to upgrade my gear box and do you know if any gears will fit in that box?
