evader squeakage
evader squeakage
ive had my evader for about 3 years and it really has been nothing but a headache.. 5 speedos, 4 motors, countless servos, but just recently when i get on the throttle, it squeaks really loud, like a loud high pitched brake, and then it takes off. Just wondering if anyone could tell me if theres a quick fix, im thinking its the blue slipper pad, but the only way i can get a replacement is if i buy the hard anodized, slipper plate, it isnt really expensive but for the pad only being like .50 cents and the plate $15, i just wanna know if theres a cheap fix, i set the diff and the slipper to where i thought it should be dont really know, never says anything in the manual, so i flattened the diff spring and let loose 3/8 of a turn, it squeals then rips, it has a 12t orion sv2 bb motor and should at least be able to get a little nose up off the ground but nothing, help would be greatly appreciated
VT
RE: evader squeakage
are you talking about these pads being worn?
http://www3.towerhobbies.com/cgi-bin...&I=LXDHJ9&P=OW
you diff could also be loose lock it down and then back off 1/16th for on road use 1/8 for on road use then tune to liking
the lug
the lug
