RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
The Official Traxxas 4wd Slash Thread...
Reply
Old 02-06-2012, 07:57 PM
  #851
FNG RIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: The Official Traxxas 4wd Slash Thread...
Practiced today. bow ties did not work,
went down 1 tooth as it was peaking out near the 3/4 mark
Goose Bumps worked and will try Suburbs on next time out
tracked straight, bite good, cornered flat, no traction roll.
car is still basically stock/ center diff/ power strokes/ roll bars and goose bumps
FNG RIDER is offline
Old 02-07-2012, 12:00 AM
  #852
OddsNEnds
OddsNEnds's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A bad day at the track is better than a good day at the office. Sounds like you still had a productive practice.....Ironed out a lot.
OddsNEnds is offline
Old 02-07-2012, 03:16 AM
  #853
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
omg thats the best saying....
phmaximus is offline
Old 02-07-2012, 10:09 AM
  #854
FNG RIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got that right!
Work is way over rated.
I had great day, it was my first day back after 1 1/2 years, First practice it was uncontrollable, and my driving was rusty.
I got it going better but timing for the triples was inconsistant. casea bunch of times : ) It got better after tire swap.
Im hopping the suburbs will hook up. the stock motor is plenty fast for now.. It felt overgeare and would hit top speedas I entered the brakiong zone. droppedon tooth.and it was a lot easier to control everywhere.
I mountedup the Suburbs last night. Will have to make some mods because the bullet connectors are rubbing on the battery bar that holds it down. theconnectors got tweeked and shorted ot the electronics temporarily.
I forgot how enjoyable it is to work on the car. I haven;t raced yet, so maybe that is it.
later days
Old 09-24-2012, 04:01 PM
  #855
clp.eng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If anybody's still out there...
I'm very new to R/C trucks.
I've built a 4wd Taxxas Slash from a roller chassis & put in the HobbyWing 1/10 BL & ESC. However, under full acceleration it jerks a couple of times before taking off. If I keep doing that eventually it will run fine. It seems worse w/ 7 cells (3300 & 4200 mAH) than w/ 6 cells (5000mAH). I tried every setting on the ESC (not sure what all of them do yet) & nothing seemed to help. Any ideas? It sure ain't fun running it like this! I have a 13 tooth pinion but it did the same w/ the stock 11 tooth. Thanks.
Chuck
clp.eng is offline
Old 09-24-2012, 05:31 PM
  #856
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
By the sounds ur batteries can't supply enough amps to the motor under acceleration from a dead stop.
U need to get a lipo the nimh batteries just don't cut it
Old 09-24-2012, 06:13 PM
  #857
FNG RIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's not the batteries it sounds like the motor is cogging, It may not be the correct motor for the Slash 4x4.
Old 09-24-2012, 06:26 PM
  #858
tabrown
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is an update on mine, doing a baja build!
tabrown is offline
Old 09-24-2012, 06:35 PM
  #859
clp.eng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
phmaximus - thanks! That's odd because I'm using the same batteries that come w/ the Slash kit! 7 cell NiHm 3300 mAH. I also tried a 6 cell 5000 mAH.
FNG rider - thanks! at low speeds under light acceleration, the motor does cog but once I accelerate through that it runs OK. It's just when I accelate at full throttle it jerks (small burst of speed then it slows down), and then repeats 5 to 8 times & then takes off normally.
What I don't understand is why it gets better as the battery wears down a bit. That just doesn't make any sense to me. I would think it would get worse as the battery voltage starts to drop. What do I know! LOL
Chuck
clp.eng is offline
Old 09-24-2012, 06:54 PM
  #860
FNG RIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your motor is cogging, a skipping or balking that occurs on sensorless brushless motors. Your motor is probably a high speed motor not designed for the heavier SC trucks. You can either gear lower with a smaller pinion or change to a sensosred system with both sensored esc and motor. You should consider a change to a high torque motor which is designed specifically for a Short Course 4x4 truck. For example the Mamba Max Pro SC 3800k sensored or a Tekin 4600k sensored motor and ESC. If you have the stock Brushless motor and speed control, they work fine and are fast.
Old 09-25-2012, 06:08 AM
  #861
clp.eng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FNG Rider - thanks for the follow up. The motor I have is an 8.5T 4000kV. I'll try the lower pinion again. Nothing in the ESC programming can help this??
Chuck
clp.eng is offline
Old 09-25-2012, 08:10 AM
  #862
FNG RIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not familiar with your motor, but it is not suitable for a SC truck.
Old 09-26-2012, 03:39 PM
  #863
clp.eng
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
phmaximus - you got me thinking about how the different chemistry packs work. I need to do some research!
I borrowed a 3S & 2S LiPo from my neighbor. The 3S was so "strong", I couldn't accelerate at full speed because the slipper clutch started slipping! But was it FASSSST. Then I tried a 2S & it was fast & absolutely no "jerking" during accelration & it was fast enough to be difficult to control! I just orded a 2S 5700mAH 50C pack! Thanks!
Chuck
clp.eng is offline
Old 10-01-2012, 03:06 AM
  #864
brianjskora
brianjskora's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Backyard Track - jumps changed a little
[youtube]http://www.youtube.com/watch?v=VYQg0rFEMus[/youtube]
brianjskora is offline
Old 12-01-2012, 09:42 AM
  #865
ShoestringRacer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys can you give me some battery suggestions for lipos..
I've only run on the included 7-cell nimh but I'm looking to buy a 2s and 3s lipo with about 5000mah preferably with the Traxxas plug already installed. Any suggestions with links would be great thanks.
ShoestringRacer is offline
Old 01-09-2013, 06:38 PM
  #866
nave88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What you guys think my first paint job it's a slightly changed Chevy pearl blue those flakes pop like crazy outside I don't even want to drive it cause it's so pretty lol[youtube][/youtube]
nave88 is offline
Old 01-09-2013, 06:45 PM
  #867
FNG RIDER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have two bodies, a beater for practicing and and shiney clean one for racing. so far the beater is over 2 1/2 years old, taped shoe gooed and patched. Sooner or later the shiney body will become the beater. and so it goes. have fun with that; )
Old 01-10-2013, 07:15 PM
  #868
nave88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This body is already my beater we had a session at work that got a little carried away... I destroyed that body, both bumpers, a shock tower, the drive shaft and slipper rod both bent and seized the motor. (Face palm) the motor was able to rebuild the rest was replaced I did all my bearings and some new screws plus a fan for the motor. this truck can take a hell of a beating
nave88 is offline
Old 01-12-2013, 06:52 AM
  #869
nave88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sux this thread is so dead hope the other slash 4x4 ones are ok
nave88 is offline
Old 03-12-2013, 01:39 AM
  #870
trx1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Working on my slash 4wd.picked out a bug body for it, also a set of rpm arms also. Has a set of street tires on it.
went with metallic blue.
just picked up this
http://www.duratrax.com/motors/dtxc3164.html
its DTXC3164 Onyx 1/10 Scale 3930kV Brushless System version.
also got this
http://dynamiterc.com/Products/Defau...rodID=DYN1071T
trx1 is offline
Old 08-07-2013, 09:09 PM
  #871
sweendog1969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by ludeman View Post
OK I love the drive shaft mod by Losifiend but has anybody come up with a mod for this problem. Why did'nt they just extend the drive shaft cover all the way? It turns out this makes a little rock trap and now my slipper nut is rounding off. So I need to cover it some how and was wondering if anybody else has already.
I used popcicle box cut to shape and used gorilla tape to keep the cardboard in shape and in place. I had the problem of rocks getting stuck between the drive shaft and chassis. My car has maybe three runs on it and the shaft is all chewed up.
sweendog1969 is offline
Reply
Display Modes
