rustler vxl vs xl-5
RE: rustler vxl vs xl-5
I think the VXLs have slightly beefed-up suspension arms too, to better withstand high speed crashing.
They used to have all metal gear transmissions too, but I think even the XL-5s have that now too.
I've been quite happy with my XL-5 Stampede. Plenty fast enough for offroad, even on 6 cell NiMH packs. The Rustlers are even a bit faster.
MN
Go VXL, trust me you always thirst for more speed, so you may as well be there right away. You can start with a 6 or 7 cell, then build up to 2s or 3s.
IL
brushless and the VXL has bearings at the wheels...the XL-5 has bushings. If you plan on running in rain or snow I would go with the XL-5 because the ESC is truly 100% waterproof and there's no bearings to rust. I have both brushless and brushed and use the brushed setup in wet conditions and it's quite nice not having to worry about damaging the electronics or cleaning out the motor. I don't even bother drying it off. If you aren't going to be running in these sort of conditions, then I'd go for the VXL.
I was figuring on putting a castle into the rustler afterwords. I didnt think it was worth the exttra money to buy the ven brushesss if the castle was a better motor.. I just wasnt sure if the vxl had that many upgrades to start..
thanks for the input, I have been darting between the losi dt, assoc t4, and even the vortex
I guess it would be nice to have a fully waterproof esc though..
If you think you're going to go brushless at some point then just bite the bullet and buy the VXL now. It will be cheaper in the long run.
The only differences in the VXL and the XL5 are the brushless setup, adjustable camber links and bearings in the hubs. Otherwise they're exactly the same trucks.
The XL5 is fast enough for most people but if you know you're going to go brushless later then just buy it done..
ORIGINAL: john01374
John... you and I are on the same page here... the only other difference I see as well is the digital servo, but Traxxas may have changed that for the XL5 as well...
Katzcratch.. If you are planning on getting the Mamba /Castle setup, then you can get the XL5 and convert the bearings.. You really don't need to worry about the camber links, the fixed ones are fine... The Digital servo is nice to have for high speed runs as it center quickly and accurately.. the analog ones don't but for normal bashing its fine... On another note.. alot of guys will remove the Velinon and sell it on Ebay or here, but you are paying an extra 180 for the truck and not going to get that back.. keep in mind the extra money also includes the upgrades... Its not really cheaper either way...
MN
Castle motors tend to over heat, i switched to VXL and it runs way cooler. Castle ESCs are said to be better though. I run Sidewinder/VXL because i burnt up my 5700 castle motor.
ORIGINAL: Littl3TuffGuy13
I just bought a rustler xl-5 and 2 extra venom 8C 4200mah batteries. Was wondering around how fast it would be. Also what could I add to speed it up once I get to the point that I crave more speed.
Venom 8cells won't fit unless you move the esc. The hump is to big. If you want more speed you need to replace the bushings with bearings in the axle carriers.
Having a problem here. I am trying to remove the stock 19 gearing on my rusty but cannot get it off. I see the small insertion for a starwrench but the one I got only seems as if it is stripping the hole. Can anyone help me out here?
ORIGINAL: bmoore83
