Is this an ok lipo charger/balancer
RE: Is this an ok lipo charger/balancer
I have the same Onyx charger since it was released and haven't been disappointed yet, I use the Great Planes balancer http://www3.towerhobbies.com/cgi-bin...?&I=LXMGS7&P=7 with excellent results, all the adapters that you would need are at the bottom of the screen
ORIGINAL: brianjskora
The vehicle is a traxxas 1/16 revo vxl. Thanks for the replies so far guys
Jeremy z- I had seen a few recommendations on these batteries and the car just needs a minor adjustment to fit them in. A friend of mine just purchased a 1/10 scale and so I will fwd him your suggestions. He is in the lipo market as well
BTW does anyone else besides me recognize the IC on the blinky? I don't have mine with me right now but it looked like a PIC16 with on-chip ADCs I'd bet.
http://en.wikipedia.org/wiki/PIC_microcontroller
#31
ORIGINAL: fourwheels0
here you go.
yes those are the right ends.
you'll also need to make or buy an adapter. tamiya female to traxxas male i think it is.
here you go.
Those Molex connectors worked for years, because the current drain wasn't high enough to melt a lot of connectors, and because they're cheap. These days, it is a bad idea to use them at all in RC.
In your application, it looks like you're just using it on the charger, and it will probably never see more than 5 A. I'd still put a good connector on that charger though.
#33
He doesn't have to, the charge plugs are removable from the charger, he needs to buy the Traxxas plug http://www3.towerhobbies.com/cgi-bin...?&I=LXVPF2&P=M
#34
MT
buying the "charge plug" is WAY more expensive than just buying some banana plugs and a male *whatever you want* plug and soldering the two together.....
It's just like the pre-mixed anti freeze at the store, they charge you more for less stuff....it's how they make money off dumb/lazy people
