@THE OFFICIAL LOSI STRIKE THREAD @
#153
ME
RE: @THE OFFICIAL LOSI STRIKE THREAD @
I don't think you can use a 16t pinion. I thought I was but I counted the teeth on mine to double check and it is an 18t one. Damn 18 and 16 stamps look alike when its that size Or I might be getting old.
#154
CA
ORIGINAL: HRCules77
As the grease has been wearing in, I've been having to make some adjustments to the ball diff and slipper and didn't have it quite set well at the time of the video. So if you listen closely, you may hear a couple sounds that would indicate excessive slipping of the slipper plates as well as the diff. It was hard to get up to speed to make the jumps but we still had fun.
Also, I have some Gamma Alpha tires coming (med. compound) that I plan to try out on the Strike. I'll post later how they work out.
#156
CA
Oh yeah, a chore and then some; especially when you're using Allen keys. Since my toolbox disappeared I haven't purchased any hex drivers. I've been looking around but haven't found a set I wanted that didn't come with several other drivers that I would never use. It's like buying RTR with worthless electronics when all you want is the chassis. I really don't like paying for stuff I don't want, but like most R/C'ers now, have joined the herd a time or two for a car I really liked. I hope I don't have to do that with the tools I need, too. I should buy some drivers soon though, since I literally blistered my finger last time wrenching on my Strike with the keys.....not to mention its a pain to try to reach some of those hidden screws. [:@]
#157
CA
At this point, I'm really not happy with the ball diff so, when I get around to it, I'm going to pull it out and put the gear diff back in. Maybe I screwed it up by not having it set right from the beginning I don't know, but now even fully tightened it slips constantly. Out it goes.
I did get the Alpha "Gamma" tires today and installed them after checking them for balance. The red dots are where the tires are heavy. Their balance is good enough for me though, and won't require me to add any stick-ems to them: I'm satisfied with them as is. The Gamma tread looks great and favorable to multiple terrain surfaces including sand/loam. It should be noted that the Gamma tread is directional.
I also tried to go for a run with my new shoes but I think my ESC is fried. I'm actually happy about this since this is the moment I've been waiting for: an excuse to go brushless. [sm=devious.gif]
Here's a few pics of the tires:
#158
ME
I've always had problems setting up ball diffs. I switched my xxx-t's ball diff for the desert truck's gear diff because I kept killing the ball diff in it.
I've been playing around with springs to help reduce body roll. I like this set up.
Blue springs on front
http://www.horizonhobby.com/Products...rodId=LOSA5160
Orange springs on the rear
http://www.horizonhobby.com/Products...rodID=LOSA5154
#161
ME
i have been thinking about getting the strike for a sct. it looks good to me.i like some of the features on it. i know about the dogbone issues. other then that nothing really. what exactly needs to be upgraded for it to stand up to brushless power.i dont mind something that needs some modding, i just am not looking for something that requires me to replace the same part every ten runs or what not to keep it going. also after the upgrades how well would it hold up. i know this depends on the driver, but in general. what im trying to get to is. would it be worth it after the upgrades or would i be better off spending a bit more cash on a different sct. thanks for any or all replies.
#162
MO
tornbb. The diff. is the main problem I have been dealing with. I have the typical outdrive and dog bones issues. I switched to the ball diff. and had even more problems. So far I would say the ball diff. was a waste of time and money..
#163
WI
i had problems with my diff so I went with a hardened spool gear and no more problems. I run a ez run 8.5t motor. oh and you should buy al. wheel hex's I went through 5 sets before I bought the al's. my friend runs a 10t ezrun brushless in his and has not hurt his stock diff or his wheel hex's. cvd's are a must but even with a 8.5t I snap them like candy. so to sum it up go with a 9 or 10t brushless or equivalent any more thing snap
#166
As long as you drill the body mount holes in the right spot for your strike then you will be sorted.
Check out proline rc for body’s, they do some nice ones, but also a factory body for one of the Losi 22s scts will work, bonus for these is they come pre printed with a paint scheme.
