heatsink for 550 size motor (like titan 12t)
ON, CANADA
ok, my bruhsless plans have grinded to a halt for now, and i would like to install a heat sink on my great planes s-600 motor. i will be using this guide
http://www.misbehavin-rc.com/pit-lan...-heat-sink.asp
with this heatsink
http://www3.towerhobbies.com/cgi-bin...1&I=LXTG84&P=7
wil the heat sink fit on the motor? there seems to be a min curvular thingy on the motor already.
with this heatsink
MN
RE: heatsink for 550 size motor (like titan 12t)
im not sure about the heat sink but your s-600 is actually longer than a 550. you may not need to cut out much. im not certain on this though
ON, CANADA
a heat sink wont help that much, you cant run your motor at 200+ thinking a heat sink is gonna help bring you down to 160,
ON, CANADA
wait i found another heatsink rated for 550 motors. i wonder if it will work
http://shop.towerhobbies.com/cgi-bin...&P=WR&I=LXNAB1
I have a couple of those Heat sinks and they are huge. They came with the HV-Maxx motors I was running in my E-maxx and Savage. Right now I'm running the same blue associated heatsink that is shown in that write up on my S-600 in a Pede and rustler. They are only slightly larger around than a 540. If you look at the can diameter it's only 1.43 where a typical 540 is 1.41. I've never had a problem keeping the heat sink in place.
Are you doing this to a Pede or rustler?
ON, CANADA
its a pede john, and the heatsink on misbehavin's guide will work?
EDIT: just read your post, and im happy now...i ll get it soon.btw im just going to vut the whole backwall of, making the installation easier.
