Brushless and ESC - how to connect
Hi,
pls I have Brushless ESC and motor, but on motor are 3 black wires and I dont know which gues where ... could you help me pls?
I made a pic and it's attached.
Both ESC and motor are from Haiboxing as upgrade kit for their car 6568
Thanks for help.
Thanks for help.
Just plug them into the ESC and then you will be able to tell.
VT
since its a sensorless system, so it doesn't matter the order, but you may find the motor will run backwards and switch the two outside wires on the motor, and that should get you going strait
the lug
the lug
OH
As mentioned, the three motor wires can be connected in any order to the motor wires on the ESC. If it spins the wrong direction (foward throttle makes the car go backwards) just disconnect and swap position of any two wires (don't do all three or you will be back where you started).
I know this has already been said, but I mostly posted because I wanted to add that you should shrink wrap or somehow cover those bullet connectors (on the ESC side) so they cannot short together when the motor is running. Maybe you already knew this, but just in case, I wanted to save you a damaged system from a short.
Previous Thread
Next Thread
