Emaxx tires..
RE: Emaxx tires..
ORIGINAL: Stampede Killer
depends, which emaxx do you have? the 2 speed with the black chassis, or the single with the grey?
if you put on tires that are shorter, then you increase accleration, but loose some top speed.
put on taller tires, and the reverse is true(up to a point) changing the tires size has the same effect on performce as changing the pinion gear size on the motor.
AZ
RE: Emaxx tires..
rim size, and the new ones tires are a little bigger in diameter
ORIGINAL: nitrosportsandrunner
why does that matter? dont they have the same sized stock tires?
