help w/repair on my redcat
figured i'd give this a shot, i'm trying to change the axle joint on my r/f wheel, its the end that attachs to the gear box. The front dog bone goes inside this piece on the inside(the outside dogbone attached to wheel axle). Redcat part # 02051 is the gear box, i have an extra 02033 and i believe this is the right replacement part (the dogbone doesnt obviously stay in since only one end is attached). I cant seem to unscrew this broken axle joint (every time i do the wheels move). And i dont believe the gear box opens up, it appears to b one solid piece. Please help.......
RE: help w/repair on my redcat
you will probably get more help in this forum http://www.rcuniverse.com/forum/forumid_427/tt.htm
thats the dedicated redcat racing forum and the owner posts there a few times a week helping ppl out
Most pople on these forums do not own redcats(or care to) due to them usually being sub standard to most other RC kit (they are one of the better brands out of the cheap ones though)
only thing I do know about them is if you can't find your part from redcat or one of their resellers you can look for it in himoto redcat and himoto both use the same EXACT part numbers just the letters infront of the #'s are different
the blow up view unfortunately isnt helping me, i've tried to use it but to no avail, i just cant figure out how to remove the old axle joint, the gear box doesnt appear to b more than one piece so it seems that i need to remove the old broken part from the outside
OH
tino, if you can get a picture of what you're trying to fix for us that would be awesome. Redcat uses non-standard names for their parts, so what they call them is not necessarily what everybody else calls them, so we're not quite up on what you're needing to fix.
Syco, you really don't need to insult the kid's car.
ALL RC's break.
ORIGINAL: SyCo_VeNoM
ALL RC's break.
ORIGINAL: ThunderbirdJunkie
ALL RC's break.
ALL RC's break.
And yes I do realize all RC's break (except it seems savages, can't seem to break mine )
ME
http://www.rufaster.com/02051.aspx
If this is the same part you are speaking about it does come apart as you can see in the pic. If you give what model car you have or as others have said a pic it would be easier to help.
thanks all
ok so inside that part (differential housing) is the gear. the gear has 2 wheel axles or wheel cups (i'm not sure what there called but the dogbone end attaches into this part). one of these have broken and i cant figure out how to get it out. I tried unscrewing it but its very difficult b/c i have to hold the other side tight and hold the gear so that they dont spin. I tried pulling it out also. I dont even know if it can b replaced, i may have to replace the gear and those 2 pieces may come attached into it.
and its the volcano epx pro brushless if that helps.
also i did post in the redcat section, but they sometimes take a while to respond and i hoped to get this thing running for this w/e but i guess that aint happening
happy 4th
happy 4th
